Question about Mitsubishi WD-52525 52" Rear Projection HDTV
HOW DO I REMOVE THE POWER SUPPLY FROM A WD-52525 ?
    Champion:
  • 213 Answers
TVtechmaniac
  • 140 Answers
SOURCE: WD-52525 with black and white little squares. it has sound.
Tile or block pattern with no video or OSD. Suspect the FMT PCB part # 930B924002.
Posted on Oct 20, 2007
SOURCE: WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Posted on Nov 29, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-52525 with no video. sound ok. B&W squares pattern on pict.
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
localwonder
  • 6784 Answers
SOURCE: wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Posted on Sep 02, 2009
Oct 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525 flashing green light reset does ot fix. have to unplug for a few seconds to fix. Is this a conputer probem inthe TV?
Ur DM power supply board have problems.U know how to solders?Capacitors bulb up or pop open.Replaced this capacitors will fix ur Flashing power.Tries website Tv repair World.com to buy these capacitors to replaced.
Apr 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD 52525 Rear Projection HDTV and it will not turn on; the green blinking timer light is the only thing being displayed. Any thoughts?
this set is prone to a lot of troubles-if you are lucky some caps in the power supply are gone--led does not ever stop blinking---if you are not lucky----DMD or dm board are bad-----the power supply in this set is a joke; these sets are dropping like flys.
Aug 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I cant disconnect my shield w/ power supplyboard from tv
There is nothing easy about this repair, I am a tech and allow 2-3 hours even now after doing many times.
Start with the sheild on the right, closest to the light engine. you will need to loosen the input jack board to get this sheild off.
2nd remove the middle shield, you will need to unplug the fan attached to it. Now you can remove the one over the power supply.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Lamp power supply
most likely the main power supply board is bad and has badd 3300uf caps
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
check the 2 3300 mf/ 10 volt capacitors on power supply board.
visible examination of these caps will often show the top of the capacitor bubbled up.
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Lamps have been known to burn out the power supply to the DM assembly. If there is no visible damage to the lamp, your problem may be the power supply or the board. Good luck.
Oct 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
How do I access the power supply? I'm Stuck!
Remove electric chassis. Power PCB is under back end cover of chassis unit.
Sep 29, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
