Question about De'Longhi DCF6214T 14 Cup Programmable Coffee Maker
14 cup coffee maker DCF6214T troubleshooting - turns on but does not work
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Replace element .
Posted on Nov 02, 2013
Delonghi coffeemaker dcf6214t clean light won't stop flashing after descaling how do I reset it to default ettings?
Hi, Cathy,
Most of the above solutions do not address your DCF6214T drip coffee maker. I had this problem, also. The manual is useless on this subject. The support telephone did help somewhat, but, also referred me to the website where I found the same useless manual.
Try this:
1. fill carafe to the 14 cup mark with warm water. (aprox 2L)
2. mix in 2 tablespoons of citric acid (a white powder available at Indian supermarkets) mix to dissolve completely.
3. pour acid into the coffee maker. and mount carafe in the machine and close the door.
4. with the on/off light off, and the clean indicator flashing press the clean button. The machine will fill the carafe over the next 3 hours, giving the acid lots of time to dissolve deposits.
5. After the on/off light goes off discard the dirty acid, rinse and refill the carafe with clean water. Fill the machine with water then mount the empty carafe in the machine.
6. With the on/off light off and the clean indicator still on, again press the clean button. This time the carafe will fill in about 6 minutes, as this is just a rinse to remove the acid.
7. Repeat 5 and 6 two more times. (I did it 3 more times, for a total of 4, but I believe 3 should work, according to the manual and the telephone support line.) (That is one acid clean followed by 3 rinses, all without pressing the on/off button.) (After all this, the darn clean indicator will still be on and the on/off light will be off.)
8. Now, make a pot of coffee and breathe a sigh of relief as you notice the clean indicator finally, turn off.
I hope this helps supliment a total failure of the manual to explain how to perform the clean operation.
Oct 20, 2012 | DeLonghi dc Coffee Makers & Espresso...
My two year old Cuisinart 14 cup just started smoking from out of where cord comes out. Is there a recall on this. There are a ton of complaints that they catch on fire
Here is a link to the Cuisinart support site: http://www.cuisinart.com/support/us.html
After unpluging the coffee maker and making sure that no one will attempt to use it please contact Cuisinart to see if the DCC-2200 is on the recall list. If it is not, you should consider installing a new power cord with at least 14 gauge wire....this is assuming that you are comfortable doing this sort of repair. Otherwise, replace the coffee maker! Fires from electrical problems are responsible for too many deaths to take any chances with an appliance that smokes when plugged in!
Jan 15, 2010 | Cuisinart DCC-2200 14-Cup Coffee Maker
Blinking on/off light won't turn off
It means it's time to "decalcify" your machine. Not sure how to do that, I assume run vinegar or something like that through it. You can turn the blinking light off by holding down the "set clock" and the "set timer" buttons at the same time.
Oct 23, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Need 14 cup replacement caraffe for Salton Coffee Maker
my glass pot broke and i need another fourteen cup i think the number on it is3044345
Sep 19, 2009 | Salton EX20 Coffee Maker, Espresso Machine
Cuisinart 14 coffee maker
Turn the function knob to "Clock," press and hold the "HR" button for a few seconds, and then set the hours. Then hold in the "MIN" button for a few seconds and set the minutes. Then turn the function to knob to some other setting to complete the time set.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart DCC-2200 14-Cup Coffee Maker
Cuisinart 14-cup coffee maker won't put out coffee
Clean it out with 1/3 caraffe worht of vinegar and 2/3 caraffe full of water - just brew the solution as if it were regular coffee - you may have to repeat this process up to 3 times.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
Leaks water from the bottom
Under warranty. Cuisinart will resolve. Thank you.
Dec 08, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
De'Longhi DCF6214T 14 Cup Programmable Coffee Maker Logo
Top De'Longhi Coffee Makers & Espresso Machines Experts
ray gallant
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
