Question about HP OfficeJet D135 All-In-One InkJet Printer
Faxing This all-in-one has stopped faxing. When sending a fax it dials out but gives the engaged tone. I thought it might be the pcb fax card which I replaced one time before when it had lightening damage (new card). This time I got a faulty d135 from e-bay as I only wanted the pcb for my own(assuming it was 'healthy') but this did not solve the problem. What should I obtain (new or canabalise from 2nd one) or do to fix it. It's a shame to replace it as it prints, scans OK. Thanks
    President:
  • HP Master
  • 2,022 Answers
Try withdirect phone line ans see. bye
Posted on Oct 01, 2007
6ya staff
SOURCE:
Cant send fax
Check whether you have dial tone by pressing [hook], if no tone, could be the fax card/PCB needs to be replaced.
Mar 31, 2014 | Brother IntelliFAX 4100 Laser Fax
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
When faxing, there is no dial tone? Have checked
Can make a call or not? If cannot, maybe your modem module faulty. Need to send it to service center to change it
May 13, 2010 | Canon PIXMA MX340 Wireless Office...
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
Mar 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
No dial tone
Problem solved - new cable bought which seems to have sorted the problem.
Sep 26, 2008 | Brother FAX 930 All-In-One Thermal Printer
Faxing
this is a standalone fax machine. check if u hav connected the tel line frm the wall to the line port on the printer & then try to send a fax. In fax mode press the option button & then press the arrow till u see on hook dial & chk if u have a dial tone.
May 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
Will not receive or send faxes
WHEN FAXING BOTH MACHINES NEED TO RECOGNISE EACH OTHERS NUMBERS (NO NUMBERS CAN BE BLOCKED) AND YOU HAVE TO PROGRAM YOUR NUMBER INTO YOUR FAX MACHIE BY RUNNING THE INITIAL SETUP
May 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Using a calling card for a long distance fax
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Apr 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
Faxmachine
CHECK 1.DO YOU GET DIAL TONE ON -ON HOOK DIAL BUTTON OR ON THE HANDSET ? IF NOT PLS CHECK THE PHONE LINE OTHERWISE--- 2.TRY RINGING THE MACHINE FROM OTHER PHONE,CAN U HEAR THE RING ? IF YES ,PLS CHECK WHAT NOS OF RINGS ,THE MACHINE IS SET TO RECEIVE, AS WELL AS SET THE CORRECT RECEIVE MODE , I.E. FAX /TEL/ANS-FAX... 3 IF U STILL DON'T GET FAX TONE WHILE RECEVING ,THEN TELEPHONE LINE CARD SHOULD BE BAD... TRY REPLACING TEH SAME ,SHOULD RESOLVE THE PROBLEM. HAPPY FAXING OMNIPRESENT HAPPY FAXING
Sep 21, 2007 | Office Equipment & Supplies
HP OfficeJet D135 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
