Question about Rowenta DG-980 Iron
I have a power strip that keeps tripping its safety switch even though only one electric oven is plugged into it. What do I need to do?
  • 438 Answers
Did you try to plug directly in to a plug ?
maby your strip is defective or has a 10 amp overload protector this will trip with heating devices of your nature.
Posted on Oct 21, 2013
My Miele rotary iron won't steam and keeps tripping the electric
have an electrician check the plug and electrics
before thinking of replacing the unit
Apr 12, 2017 | Miele Irons
Tip
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
My tefal keeps tripping elcb in fuse board what could be wrong
Next time it happens and it trips.. use a dry towel to unplug kettle, just in case.
Is the base wet? Check the kettle for cracks. Check the cable. Is it damaged? Try replacing the fuse in the plug. Is the steam that the kettle produces affecting lighting or other electrical items around it? Try moving the kettle to a different location.
Aug 05, 2015 | Tefal Irons
My Iron keeps tripping the fuse in main power box what is causing this it doesn't happen with any other appliances?
Tripping the breaker or fuse as you call it is caused by excessive current draw. These are safety devices that are meant to protect from electrical overloads and fires. More than likely your iron has a failing heating element and should be replaced. If it is a steam iron it is also possible that it has developed an internal water leak causing a short. Continued use is unwise and a potential safety hazard.
Feb 19, 2015 | Irons
Tefal easycord keeps tripping the elcb
The ELCB tripped whenever the plug switch is on.
Jun 08, 2012 | Tefal UltraGlide Easycord FV4256 Iron
My iron trips the safety switch and causes a blackout of a third of the house. Is there anywhere I can get it checked for free? I live in East Fremantle, Western Australia. It cost $130 about 12...
This must be easay if you have a multimeter to check, The power plug must have a clean continuity to the coils of the iron. It is possible that the cord is short and so the short seems to make the circuit trip. To confirm remove the main power cord from one end and check for short in the wire. If the mains and neutral shows a short with one wire taken off from the iron then the wire is short. If not the short is within the iron that can be checked in the similar manner.It can also be a very minor problem of a wire sticking to short within in the control.
There are many good brands, Philips, Rowenta,Black and Decker, Panasonic etc.. choose one which suits your need.
Jan 11, 2011 | Philips Irons
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
The ps 300 will not heat although the on light is on
I bought one of these units at a Salvation Army Store still in the box brand new. I experienced the same problems (power was lit, but the breaker would trip and turn unit off). I opened the unit up and since I have knowledge of circuits, I bypassed the breaker (trips when it reaches a predetermined temp). I did however add a CRUCIAL electrical component that makes this possible an keeps your house from burning down - a added a simple dial thermostat (like one from a single electric plug-in coil stove top). Bottom line, I took on this project moreless for fun and I would NOT RECOMMEND anyone try this unless you have some knowledge about electrical circuits.
Feb 18, 2009 | Homedics PS-200 Iron with Auto Shut-off
General electric light 'n' easy iron tripping safety switch
it is shorting out and tripping the breaker either from moisture or problem insulation
the cost to repair is more than a new iron so junk it and be safe
Jul 12, 2017 | Irons
Rowenta DG-980 Iron Logo
127 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
