Question about Magic Chef Washing Machines
Water from washer in bathtub - Magic Chef Washing Machines
  • 2,113 Answers
Either your drain when plumbed wasn't installed with a y that allows smooth flow past the tub... or it bottle necks too much and needs the over flow to get down the drain. Or the drain size should be enlarged to 2 inch instead of 1 1/2 inch. If the existing drain is galvanized then it narrows with age. The drain lines may not have enough lean and have deposits on the bottom that need a plumber with a root cutter bit on an electric eel to get removed. (rental eels are just not good enough). Also is this drain vented properly to allow the air to move aside so as to allow the water to run down smooth?
Posted on Oct 20, 2013
How do I fix a dripping bathtub faucet?
most likely washer in tap is worn.
https://www.youtube.com/watch?v=VyfL2wLqPbA
https://www.youtube.com/watch?v=yflwG8IkRO8
also note the comment in you tube about the rubber washer seal could be a cause.
https://www.youtube.com/watch?v=LV9HIEhr1G8
Nov 04, 2015 | Home
Kenmore elite washer little amount of water fills washer
If I am understanding the question, you have low water pressure/volumn when washer is filling? If so, unplug washer. Shut off water at valves. Remove water lines from rear water inlets on washer. Clean debris from screen filters in water inlets or in supply lines. Flush supply lines into bucket. Reconnect water, power, and test.
Jul 22, 2013 | Home
Bathtub faucet won't turn off
You need to shut off water to bathtub take cartridge out(be sure to note or mark position cartridge came out so it goes back same way)replace springs and washers.Pop out old springs and washers with small screwdriver or pick tool.
Jun 03, 2011 | Kohler Plumbing
The water in the bathtub won't shut off. Its a one lever on off. I turned the cold water off but the hot water still leaks out of the fill tube a little bit. Why won't the valve shut off the water
washer and or cartridges have failed and need to be replace to stop your leaking faucet. If it becomes to bad before you can repair them, you may wish to shut off the hot water valve to keep it from wasting hot water.
Dec 28, 2010 | Home
How can i find the main water turn off; the cold water tap, for the bath, needs a new washer
if it is not in,under or right outside your house you can always shut it off at the water meter,usually located on the property line under a metal cover. use a crescent wrench or channel lock pliers. if more than one family is on this one meter, notify everyone involved about your repair problem and co-ordinate a time to turn off the water that is convenient for everyone.
Sep 16, 2010 | Whirlpool 67"x30" Cast Iron Claw Foot...
Galbocca jacuzzi type tub with plug that won't hold water in the tub.
Remove plug fitting and reseal or someone forgot to install the rubber washer.........Silicone and replace because the water is leaking through..Hope this helps.
Aug 11, 2010 | Whirlpool Hydrosystems 72 X 36 Biscuit ...
I have hot water in my bathroom sink,but not to my shower/bathtub all of a sudden.I went and checked the line and felt it,still plenty hot.I turned the valve off and back on,came back inside and had hot...
You don't indicate what kind of valve(s) you have in your shower/bathtub.
It is sometimes the case, when you have separate hot and cold valves that use the traditional flat washer, the rubber/viton washer wears over time and actually becomes cut, such that a part of the washer protrudes from the valve face.
Hot water will cause the distorted washer to expand. Consequently, as more and hotter water flows through the valve, the washer expands to the point where it constricts the flow of hot water.
Replace the washer, at least on the hot water valve.
Aug 11, 2010 | Heating & Cooling
Bathtub water constantly runs (hot water)
the washer's are most likely history,you will have to remove and repair .check for access panel behind tub. there may be shut offf valve's .don't know if your handy,or not but not that hard ,or call your plumber!!
Jan 02, 2010 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
Hot/cold cycle works but w/out hot water
I got my washer from a friend and his did the same thing. I have to put the washer on normal for cold water and heavy load for hot water.
Apr 15, 2009 | Hotpoint VBXR1090B Top Load Washer
Bathtub water jets . is there a way to plug / close them
try using dish washer tablets in water they clean out tubes 3/4
Mar 02, 2009 | Whirlpool Home
Washing Machines Logo
48 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
