GU2475YTVYI Normal wash button continually flashing, when cancel button pressed it too continually flashes. This occurs when attempting to start machine. Resetting power switch makes lights disappear, but the Normal wash light goes back to blinking continually when you try to start machine again.
There is a trouble shooting document behind the kick panel at the bottom of the machine. Follow the steps to determine which component is at fault. It may be corrosion in the low voltage connector.
My whirlpool dishwasher gold GU2475XTVQ0 had rapid blinking lights that started with the "4 Hour Delay" LED and changed to others when other buttons were pressed. The machine would not run. I followed the instructions located behind the kick panel and verified the keypad was the issue and not the control circuit by elimination.
The big surprise for me was that when I used a straight pin to resistance check all of the buttons, they checked out OK. I reconnected the 14 pin connector (P1) to the control and found that the buttons/LEDs were behaving correctly! I believe that pushing the straight pin into the 14 pin connector removed any corrosion in the 10 year old device and permitted the keypad to communicate with the control again.
I reassembled the dishwasher door and it ran with no problems. I was ready to replace the keypad for $150, but didn't have to!
SOURCE: Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
SOURCE: Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
SOURCE: None of the Wash Cycles are Working
It's probably the touchpad - commonly used buttons quit working after a while. If not, then it's the electronic control board.
SOURCE: clean light
you may a a latching issue. d/w not latching properly. How long does it take before the clean light comes on after you reset it. does it fill with water? if so, then your motor may be defective.
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When
the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all
buttons are non responsive). It does this as a safety in case the
element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes).
You should now be able to run the dishwasher as normal.
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring).
It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
