Insall a 50A55-743 integrated furnace control board on a goodman furnace
machtcl1
  • 61 Answers
SOURCE: furnace starts properly, then shuts down, led flashes 8 times
The first thing to look at is the flame sense rod.
Shut off power to the furnace, remove, clean sensor with steel wool or sandpaper then reinstall the sensor. Reapply power and it should run properly.
Posted on Jan 10, 2009
gtmerkley
  • 190 Answers
SOURCE: I have a Goodman GMH95/GCH9 furnace, the
open the front door to the furnace to access the controls there should be a red button try pushing it to reset
Posted on Oct 10, 2009
  • 9 Answers
SOURCE: Goodman GMPN060-3 Furnace will not stay lit.has
possible faulty gas valve if all fail safes stay closed. make sure flue is clear for pressure switch to stay closed.
Posted on Dec 16, 2009
  • 3315 Answers
SOURCE: I have a Goodman GMPN080-4 furnace. The light on
Hi 3 blinks should mean it is the pressure switch there should be a code in the manual or inside of the door
Posted on Jan 30, 2010
kingbrizzle
  • 407 Answers
SOURCE: Goodman Furnace not working again????
You can try the 4 amp fuse thats on the inside of the unit, on the board, if you feel confident that there is 120v going to the unit. Having issues with the board can be a bad sign and not knowing what they have already done to it kinda leaves me in the dark, but you can try that and if the fuse blows again, you have other problems going on that they will have to trouble-shoot. The unit is still under the 5 year warranty so it might be best to try and get another board all together, you should only have to pay labor cost. It could be the transformer too, you can check it with a meter to see if your getting the 120v going in and 24v going out if capable. Hope this helps some and good luck!
Posted on Jul 14, 2010
My goodman GMVC95 furnace circuit board is flashing On 6 I replaced the flame sensor but it's still flashing. Does it have to be manually reset?
Alright, have you checked the low voltage fuse on the circuit board in the blower compartment? Make sure you check the roll out switches as well. If all of these issue appear to be fine then you may have a bad circuit board. There has been a bad batch of circuit boards going around many of the popular furnace brands this winter. Trane Gas Furnaces and Goodman Gas Furnaces have been effected. We sell both brands and have had to replace many circuit boards on new furnaces. Trane Gas Furnaces Installed Goodman Gas Furnace Installation Gaithersburg
Feb 03, 2018 | Goodman Heating & Cooling
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Insall a integrated furnace control board
Hi friend'
I know the best company for furnace visit this company
http://www.cambridgeheat.com/
Oct 20, 2013 | Heating & Cooling
Goodman furnace fan runs all the time
Hello, this can be caused by a bad relay on the integrated control board or a short in the low voltage wiring. Easy way to check is unhook the green wire from the G terminal on the control board, if it stops there is a short in tje wiring, if it does not stop the control board must be replaced due to a bad relay.
Oct 28, 2011 | Goodman GMS90703BXA Heater
Furnace wont run ...thermostat battery went dead i replaced the batteries and still furnace wont run...We recently had a power outage for approximately 12 hours. This furnace is in our garage. we had...
Hello, The first thing you need to check with a multimeter is if you are getting 24 volts between the R AND C terminal on the intergrated control board. If not than the transformer is blown and needs to replaced or the fuse on the control board has blown and will need to be replaced. When check for 24 volts at the R and C terminal make sure the door switch is pushed in, u can just use electrical tape to temporaily hold the switch in. If you are getting 24 volts at R and C and notthing continues to run than the intergrated control board is most likely the cause and must be replaced.
Feb 04, 2011 | Goodman GMS90703BXA Heater
I HAVE A 45000 BTU GOODMAN FURNACE RED LIGHT
There may not be a call for heat being registered by the control board. Take the R and W terminals on the control board and put a jumper between the two. If the heater starts, you have either a broken thermostat wire or a bad thermostat or connection.
Jan 25, 2010 | Goodman Heating & Cooling
Goodman GPM075-3 air conditioning connections
your thermostat powers 'Y' for cooling. That in your case blue wire connects to 'Y' on the control board in the furnace. Then a pair of low-voltage wires connects 'Y' and 'C' on the furnace to the two wires to the coil of the contactor in the a/c condensing unit. So to follow the path, the signal wire from the thermostat sends 24v down the Y wire to the furnace board Y terminal which also connects to one side of the contactor coil in the air conditioner. To complete the control circuit to the air conditioner there has to be a common wire. This is connecting the C wire from the furnace board to the other side of the contactor in the air conditioner. Hope this helps.
Dec 11, 2009 | Goodman Heating & Cooling
I have a Goodman GMH95/GCH9 furnace, the integrated control module LED is flashing eight(8) time and the troubleshooting chart only goes to seven(7)
Oct 10, 2009 | Heating & Cooling
Furnace integrated control module
The light is supposed to be on, if there is a fault in the furnace the light will begin to give u a flash pattern... ie; three flashes...or two flashes.. on the furnace exterior or on one of the doors there should be a fault code chart.... read the chart on the unit it will tell you what light is on and when..
Jan 14, 2009 | Goodman GMS90703BXA Heater
Furnace starts properly, then shuts down, led flashes 8 times
Jan 10, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
