Question about Toaster Ovens
Fan is not running - Toaster Ovens
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Replace fan or replace toaster oven. I am sure you will d=choose the later...not worth the repair cost.
Posted on Oct 21, 2013
Fan motor
maybe you have stain in motor shaft! you can clean the motor by spraying of WD40. or maybe you have defective fuse thats connected to motor to source! or try to clean the rotary switch!
Oct 14, 2007 | Maximatic RO-1010X 1500 Watts Toaster Oven...
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
It wont turn on model T0131SWD!!!!!!!
follow this charter troubleshooting and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2gUR97IFo
Oct 01, 2013 | Black & Decker Toaster Ovens
Need to buy replacement fan blade but I don't need the entire fan assembly. Could you help?
DON'T KNOW HOW OLD IS YOUR OVEN BUT IF YOU CAN REPLACED THE MOTOR AND FAN BLADE , ((PROBABLE ONE OR BOTH PART ARE DEFFECTD)) YOU MAY CONTACT SEARS THEY MAY GET THE PART FOR YOU CHECK IF YOUR OVEN HAS ANY WARRANTY CALL 1800-4MY-HOME JUST GET MODEL#
Feb 18, 2011 | Anvil COA8005 6600 Watts Toaster Oven with...
My bread burned on top before it was done ,using convection oven
I would say that it sounds like the bottom element isn't working. I am assuming that you can tell that the fan for the convection feature is running. You should be able to see through the glass door to see if the element is heating up.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 17, 2011 | Hamilton Beach Toaster Ovens
Whirlpool fan assisted oven - fan motor coil burning out
The PCB board is definitely at fault here. One of the dc voltage lines is transferring too much current. The regulator and resistors are probably compromised. The better option is to replace the board than to try and fault find the components.
please rate my help++++Thanks for using FIXYA
Jun 23, 2010 | Toaster Ovens
Fan turns on and off during cooking
mine says the fan will turn on and off to keep the computer board cool... probably normal
Jul 31, 2009 | Toaster Ovens
Toaster Ovens Logo
49 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
