Question about Bissell Vacuums
Bissell pro heat pet 89104 will not spray water
SOURCE: My bissell pro heat power brush won't spray from the floor unit
my bissell quicksteamer wont spray water
Posted on Jan 24, 2009
SOURCE: bissel pro heat 2x wont spray any water
I had the exact same problem with my ProHeat 2. It would spray only through the hose attachment but not on the floor. Cleaning of the spray endings on the floor unit fixed my problem. Either soap deposits or dirt was clogging the spray endings. Here is what to do to clean up the spray endings:
1. Remove the water container from the bottom unit
2. Look up for two red plastic endings on the bottom unit
3. Using your fingers to clip sides of an ending, carefully remove it from its slot
4. Using pliers, release the clamp from plastic ending and remove the red plastic ending from the hose
5. Clean the ending
6. Put the ending back on the hose, slide clamp back on the ending
7. Insert the ending back in its slot
8. Repeat 3-7 for the other ending
That solved the problem for me!
Posted on May 17, 2009
  • 29 Answers
SOURCE: Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
  • 29 Answers
SOURCE: Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
  • 17 Answers
SOURCE: my bissell pro heat 2x will not spray water to
Here is the fix
Posted on Feb 08, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My machine will spray from the hose attachment, but not when I am doing floors.
Check Flow Indicator Filter under the Flow Indicator. Turn Indicator cap counter-clockwise, remove rotor. Filter is under rotor and pulls out. Clean filter. Additionally, check LINT FILTER in the clean water tank cap. Check you User's Guide if you have more questions or call the Bissell Consumer Care at 1-800-237-7691 The other thing you can do in this case is reseat the tank. It may be blocking the housing connection but the sprayer connection is smaller and open. Cleaning the filters after each use though is recommended.
Dec 06, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
Water will not spray out.
Try this link to fix it :-) http://www.bissell.com/support/helpful-resources/faqs/faq-detail-page?id=351b340d-bf2f-4941-bcd0-c1b1cab3d083
Nov 14, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
Cleaning fluid leaking out and machine not suctioning up water
First thing is clean the filters: Heat tank filter on the tank cap, and then the Flow Indicator Filter (turn the Flow Indicator Cap counter-clockwise and remove, lift rotor and filter out. Clean filter and reinstall in reverse order) Consumer Care # 1-800-237-7691
Aug 16, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
Cleaning the tubes on the heater of a bissell proheat pet
just simply take a half a bottle of bleach poor it in the clean water tank use the hose and sprayer on a clean hard surface it will spray the clean bleach and suck up clean bleach and the bleach will do the job for you
Mar 18, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
Not spraying water and solution
Tanks may be empty or not properly seated.
-Fill up the bladder with hot water and the solution tank with proper cleaning liquid.
-Remove and reseat both tanks
Pump may dry, needed to prime.
-Turn "off" power wait for about minute turn "on" power and depress spray trigger.
Check and clean filter on the deck (under the clean water tank, a red slotted plastic screw)
If nothing works you have to open the deck cover and go into details: check the pump, its a 12V DC motor, the solenoid, its a valve which operates with 120V, the hoses for broken or pinched part, the diode bridge (creates about 12V DC for the pump if the vacuum motor is turned "on" and the secret fuse (3,15A under the heat-shrink series to the diode bridge, if this one goes, no power to the pump!)
Mar 09, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
Bissell pro heat 2X pet will not spray water.
Bissell 2X machines all seem to do this after 4 or 5 uses. It's a bad solenoid. Most vac shops won't touch the 2X with a 10 foot pole. Get a Hoover 5914 and stay problem free.
Oct 18, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
65 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
