Question about Furniture
Whisperkool 1600 xlt developed a drip from the right fan after many years of trouble free operation. What could be causing this?
  • 2,113 Answers
Http://www.luxewinecellars.com/sites/all/files/product_downloads/whisperkool-xlt-owners-manual.pdf
i was just reading the manual for you. This make not be the exact manual But once a year you have to clean the fins, bleach the inside etc. make sure the drain hose is not blocked with goo, or deposits etc.
Posted on Oct 20, 2013
We have several 11 year old Craftmade ceiling fans that have developed a ticking sound, mostly on the medium speed. Is there a way to lubricate them or is there some other way to stop the ticking?
Several things besides lack of lubrication can cause the problem.
One or more of the fan blade irons may be loose. As well as the wooden blade itself. In both cases a Phillips screw driver will solve the problem.
The pull chains are clicking against the the fan. I've see this happen many times. Simply putting some tape around the chain, where it touches the fan, will generally silence it.
And last, but not least ... The fans may be out of balance. But, this may be due to loose screws in the fan blade irons.
As far as lubrication is concerned. Older unit (10 to 15 years) have sealed motors that were to be permanently lubricated. Even some of today's brands and models are too. At best, if none of the above silenced the ticking, is to use a little WD40 with a straw nozzle up into the fan housing. Be careful doing this as the WD40 may drip. Be sure the wall switch for each fan is OFF, before attempting this.
Hope this helps you and thanks for choosing FixYa.
Aug 27, 2011 | Heating & Cooling
When the pump is running, if I turn on the cold water faucet the check valve opens and closes rapidly making a loud knocking sound. This problem only developed after four years of trouble-free operation.
Clean out check valve with CLR calcium-lime-rust and see if functionality is restored.
Problem can also be caused by air bubble inside the line, caught at the check valve. Dissemble and reassemble parts. Install air vent.
Another option is to install direct return line with in-line check valve and air vent.
Parts can also be ordered.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 24, 2011 | Laing Thermotech Autocirc Undersink...
2003 Ford Expedition XLT 4X4 4.6L. 70,000 miles. Had a rough idle then stalled. Happened 4 times today. CEL reports a lean left bank. Just finished changing spark plugs and fuel filter. Plugs were fine....
Cam Phasers. There is an Extended Warranty for them. What happens is the Cam Phaser is suppose to automatically adjust each cylinder bank independently. When one of the Cam Phasers gums up, it can leave a Cam over-advanced.
An over-advanced Cam will be lean and generate a lean Code for that side of the engine. An engine with one bank operating at 1 timing setting and the 2nd bank operating at a different setting will run rough and stall before blowing up.
Ford has given a 7 Year, Limited mile Extended Warranty for those DOHC engines having this problem. This can be a costly repair of around $2400. A recently developed "Cheater Procedure" can cut Labor from 8 to 4 hours with savings in gaskets resulting in a $1200 to $1600 repair.
Your vehicle may develop a Diesel sound which fades at 2000RPM. So contact a Dealer with a VIN# and go from there.
Jun 19, 2011 | Ford Expedition Cars & Trucks
The Whisperkool 4200 unit is no longer cooling the wine room. The digital display is jumbled and will not reset when unplugged. The fan runs constantly but the wine room is only be cooled to 64 degrees. I...
Version:1.0 StartHTML:0000000149 EndHTML:0000001329 StartFragment:0000000199 EndFragment:0000001295 StartSelection:0000000199 EndSelection:0000001295 All WhisperKOOL units come with a 2 year parts and labor warranty with a 5 year warranty on the compressor. During the warranty period, if the unit fails a replacement unit is sent at no cost to you. If your unit fails after this period we offer a Consumer Care Program to give the customer a chance to get a new unit at a deep discount. In many cases, the failing unit has been misapplied and the correct unit for the installation is sought after during the replacement process. Our customer service department is trained extensively, with live customer service representation with a streamlined process for not only helping with the products, but also assisting in identifying any limitations to the installation or ventilation of the cooling unit.
If a repairing the unit is the decided route, call WhisperKOOL directly at 1-800-343-9463 and parts can be ordered depending on availability. A knowledgeable HVAC Professional should perform any repairs due to the refrigeration system.
Jun 30, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
Nobody has answered my question!
check freon and fan motor and maybe your thermostat
Mar 02, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
Whisperkool 4200 icing up
Hi, Bob:
Misery loves company, so I'm posting this even if it isn't in time to help you.
I had an XLT 8000 with similar problems. Vinotheque wanted to do the exchange program ($2,500+), and I was told the older aluminum coils might have leaked, and the exchange models come w/ SS coils. I was near to biting on that, when I decided to have a local refrigeration shop check it out.
Here's what they found--A MANUFACTURING DEFECT. It seems there are small copper capillary tubes that circulate the refrigerant. If they touch each other, with normal operating vibration they can wear holes in each other and the refrigerant can leak out. The leak can be very slow. According to the guy who fixed it (all for $219, and much of that was for drilling out the riveted-closed enclosure), "crossed cap tubes" is a Bush League mistake, akin to not putting oil in your car's crankcase.
I'm not saying WhisperKOOL/Vinotheque did this on purpose, knowing there would be an eventual failure and an opportunity to make another sale. But what the service guy told me was that IF the manufacturer was without scruples, a crossed cap tube would be the perfect way to take advantage of an unsuspecting customer.
My fix? Drill out the rivets, and find a local qualified service tech. Fixed in hours for $219 or in weeks with an exchange for $2,500... You choose.
Sep 25, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
93 explorer dripping oil over night from bottom of car
clean the srea and watch, tracing back to the source. The oil can leak from the front seal, rear main seal,Pan gaske, or come from the top of engine. Chances are greater it's coming from the front because of fan draft. good luck
May 29, 2009 | 1999 Ford Expedition
Ice is forming on the outlet holes on the face of my 4200 xlt
you should check to see if the fan at the back of the unit is operating, and you also need to check for dust build up, if the fan is working then clean and defrost the unit, try it again, make sure there is nothing blocking the airflow, if the motor is not running, replace the motor, hope that helps
Jan 18, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
Jan 18, 2009 | Heating & Cooling
Cool air outlets frozen over with ice
And the temperature hasn't changed at all (still set at 55ºF)? A troubleshooting guide says you can check if the cause is because too much heat was lost to adjacent areas, and you can try to add more insulation around the ductwork and ensure doorways and glass panels are sealed. Other than that... not sure. If it's older, maybe you can look into a new Whisperkool split system or cooling system (there's some great ones on http://www.vintagecellars.com).
Jan 02, 2009 | Vinotheque Whisperkool 3000 Wine Cooling...
Furniture Logo
66 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
