Question about Whirlpool RBS275PD Electric Single Oven
I cannot get the stovetop to turn on . I have a gas oven and the electric igniter comes coming on but no flame appears. mike s
    Problem Solver:
  • 16 Answers
Probably the gas valve is bad
Posted on Nov 01, 2013
  • 50 Answers
SOURCE: oven has gas smell
all you need is a regulator or a thermostat
Posted on Feb 24, 2010
  • 1891 Answers
SOURCE: Oven will not ignite because the gas is not coming out.
not a good way to light the oven . so do ck for the loose connection . as cooking will be much easer.. if gas ck the ignitor and if elect ck the connections on range pig tail ( power cord ).. mm hope t this helps...
Posted on Jul 16, 2010
heatman101
  • 43501 Answers
SOURCE: Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Dec 27, 2010
  • 403 Answers
SOURCE: My oven/stovetop isn't turning on,
To lock/unlock the controls: Turn all surface burners off.
Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
Posted on Feb 11, 2011
  • 88 Answers
SOURCE: when turn oven on can see the igniter coming
You need to replace your igniter. Very common replacement part.Igniters can look ok but can be failing and not drawing enough amps to open gas valve . Disconnect power before attempting.
hope this helps
Posted on Aug 15, 2011
Trouble shoot oven
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 26, 2015 | Whirlpool Ovens
Was adjusting the temperature dial when oven shut down clock is off as well and electric gas lighters for elements not working, what would cause this - I have checked the power supply box and it is fine
clock must be set to correct time or it will hinder proper operation of oven
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 18, 2015 | Ovens
Oven ignitor intermittent spark, oven wont light, emits gas.
ELECTRIC OVENS:
Mar 13, 2015 | Ovens
Zanussi gas cooker gas not coming through no ignition
GAS OVENS
Jul 30, 2014 | Zanussi Ovens
What can I do to fix my Wirlpool Gas Oven? Mo. # WFG361LVB
i would check my oven gas safety valve first
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
May 16, 2014 | Whirlpool Ovens
NATURAL GAS OVEN WONT COOK PROPERLY
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
Frigidare gas oven wont ignite
ELECTRIC OVENS:
Feb 07, 2014 | Frigidaire Ovens
There is no gas flow to one of the ovens igniters
GAS OVENS
Jan 28, 2014 | Viking 30" Professional Select Built-in...
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Whirlpool RBS275PD Electric Single Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
