Question about Konami Video Game Consoles & Games
On Metal Gear Legacy I cannot find how to get the original Metal Gear 1 & 2 NES versions. Please Help.
Does the original Nintendo NES-001 require a certain AC adapter. Cause I doesn't have the original ac adapter with same spec. My console power light is blinking on an doff. can that be the issuept
As long as it's 9 volt and about 500mA it should be ok. Just seen an original that says 9 volt and 400mA.
The current (mA) can be higher than the original but not the voltage that has to be 9.
1000mA = 1 Amp. So anything over 400mA is fine, but not less.
Feb 05, 2012 | Nintendo NES Console
How do you get the controller to work for fc game console usa version
The yobo controller are cheap. A master gamer would lose a fight with these controllers. If u has the original super nintendo controllers use them or try to find 1 online to purchase, they work
Dec 30, 2011 | YOBO FC Game Console
Can the ac adapter for the original NES console cause the console to flicker after 4 minutes then and why?
  • Well yes or the outlit thats its plugged into might not be working right and its not getting enough power to work right then.
    • Well it depends if the ac adapters metal parts on it are really loose or crooked then then yes or if there is something wrong with the inside of the adapter than yes
    Jun 16, 2011 | Nintendo NES Console
    Lookin for super mario game for psp
    If you are looking for an actual super mario game it is not sold for psp. But if you have a hacked firmware you can run an emulator.
    Mar 04, 2011 | Video Game Consoles & Games
    Need help please !!!!!!!!!!!
    check your transmission fluid with the engine running and gear in park. check the level, color, smell, and feel it. adjust level if needed, if it's black, smells burnt, or you feel small metal like shavings, your tranny is junk.
    Aug 02, 2009 | 1991 Subaru Legacy
    How can i download games for my mp5??
    If your MP5 supports '.nes' games like mine does, then try downlading .nes ROMs...
    .nes are originally Nintendo Entertainment System files
    Jun 01, 2009 | Nintendo Donkey Kong Country 2: Diddy's...
    Need a simple list of Original Factory IRQ settings.
    The one here is version A03. I don't see options for setting IRQ's.
    Except for the main, under each tab on the BIOS page, there is a menu item "F9 Setup Defaults". Selecting "F9" loads the factory settings for items on the page. ("F9" on any may load all, but I'm not sure) I saw a "Legacy" for USB, I would have that enabled. The default settings must work regardless of the BIOS version.
    Jan 04, 2009 | Dell Dimension 4500 PC Desktop
    I dont know how to plug my NES into my t.v.
    If you are talking about the original Nintendo the original cable that came with it will hook up 3 different ways 1) way is through the vcr through the rca inputs ,2)if your tv is capable use an S-video cable. You can also run it through some of the satellite boxes. 3)hook the tv end of the able to the tv and sat to the little box.
    Jan 02, 2009 | Nintendo Super NES Console
    Nes flashing black and white and making a horrible sound
    a 'front load' nes ALWAYS does this, even if the connector pins inside the console are new. the cartriges on a Front Load nes rarely completely seat, as Nintendo redesigned the Famicom very poorly for the US market. try this 1. put the cart in as usual, but hold it all the way down 2. slip an unwanted/extra cart in on top of the metal hoop above the cart your using. this gives a better contact for the cart. try cleaning the cartrige pins as well. some won't read right if there's ANYTHING on the pins.
    Dec 03, 2008 | Nintendo NES Console
    Original nes
    It's a NES, after the light comes on the system works just got to try all the little tricks from back in the day of cartridge games.
    blow the game out reinsert try again
    the 1...2....3 push down trick
    just got to play around with it now to get a picture
    Jun 12, 2008 | Nintendo NES Console
    Video Game Consoles & Games Logo
    470 people viewed this question
    Top Konami Video Game Consoles & Games Experts
    Tom Chichester
    Are you a Konami Video Game Console and Game Expert? Answer questions, earn points and help others
