Question about Panasonic Televison & Video
Fault finding - Panasonic Televison & Video
  • mikadot
    mikadot Oct 20, 2013
    Many CRT tvs have a main ic or eprom (eraseable programmable read only memory) that may need replacing too
  • 2,113 Answers
If your tv does not turn on at all Look for the voltage rectifier, voltage regulator. Diodes and resisters in the power circuit. Burnt solder traces, the flyback transformer, the horizontal and vertical output transistors. and especially bulging or dry electrolytic capacitors (which is what caused all of the others to fail) The symptoms that the electrolytic capacitors need replacing are lines on the screen, and later black bars on the top and bottom of the screen. To test any semiconductor use a solder ****** and a solder gun to remove the solder gently until you can remove each part test using a multimeter on diode setting. test the legs in any order for open circuit or short circuit if you have a high reading one way and a small reading the other way then the component is good. Any component that gets hot enough to need an aluminum heat-sink is suspect.
Posted on Oct 20, 2013
Simpson esprit 450 washing machine. Sometimes it will do the final spin and othertimes not spin at all. The machine is 11yrs old.
Probably a timer problem but you need fault finding knowledge and a test meter to find the fault. There are a few other reasons to not spin. You haven't said if you have a test meter or fault finding skills.
Oct 20, 2017 | Simpson Washing Machines
Tip
Fault finder Home electric main fuse
If the fuse in your home is geting down on main fuse. and you dont now wher the fault is. Check: 1 take all fuses down then take the main fuse up. 2 take one after one of the other up then you find the fault becaus the main is geting down when you com to the fault fuse virring. 3 take out all component of the grid on this virring/conection se if the main fuse stans or fall.if it stand, plug one and on into the grid. then you can find the fault component and fiks that/or bye a new one. God luck.
on Dec 04, 2009 | Kitchen Appliances - Others
Kenmore dishwasher is flashing E2f2
duplicate question > This appears to be another ... posting same answers
Appliances branded with the Kenmore logo and sold through Sears are produced by other major manufacturers.
So First: Using the Sears Model Prefix Chart, find out which manufacturer produced your appliance to find the right repair information. Locate the model number on your appliance and match up the first three digits before the decimal point of the model number to find the manufacturer.
Then search the appropriate manufacturer Fault codes to diagnose (and hopefully fix) the problem
.http://www.partselect.com/JustForFun/Fault-Codes.aspxwww.partselect.com/JustForFun/Sears-And-Kenmore-Appliance-Fault-Codes.aspx
Sears and Kenmore Appliance Fault Codes
Jan 29, 2015 | Kenmore Dishwashers
Lights flashing E2F2 on kemore dishwasher
Jan 29, 2015 | Kenmore 24 in. 17482 / 17484 / 17489...
Help!!!cant find what fault code means
P4040 code that is a non specific code that could be either EGR control circuit malfunction or security shut down mode meaning that the security system is shutting off the spark and/or fuel.
Sep 20, 2014 | 2001 Daewoo Lanos
Washer fills and washers btu won't drain or spin have already replaced the water/drain pump but still will not drain Model number is GLWS1339ESO
This applies to most washers:
Loss of power to a drain pump and /or drain valves can usually be traced to two main problem areas:
1. Faulty timer (aka rotary control) units
2. Discontinuity due to wire fatigue or loose connections.
Fault finding of #1 can be difficult, particularly if the person doing the fault finding does not have the necessary tools, and does not understand machine logic or the steps that create the whole.
Fault finding in the case of #2 is somewhat easier, since visual and/or manual inspection is a great aid. However, a multimeter is still an almost indispensable tool and allows easier fault-finding and diagnosis.
Feb 12, 2011 | Frigidaire Hardware & Accessories
Check abs system lite on how do you find the code list
ABS Fault Code List 1991 Corvette (C4)
Code Definition
21 Right Front Wheel Speed Sensor Fault
22 Right Front Toothed Wheel Frequency Error
25 Left Front Wheel Speed Sensor Fault
26 Left Front Toothed Wheel Frequency Error
31 Right Rear Wheel Speed Sensor Fault
32 Right Rear Toothed Wheel Frequency Error
35 Left Rear Wheel Speed Sensor Fault
36 Left Rear Toothed Wheel Frequency Error
41 Right Front Solenoid Valve Fault
45 Left Front Solenoid Valve Fault
55 Rear Wheels Solenoid Valve Fault
61 Pump Motor or Motor Relay Fault
63 Solenoid Valve Relay Fault
71 Electronic Brake Control Module Fault
72 Serial Data Line Fault
75 Lateral Accelerometer Fault (Short ot Open)
76 Lateral Accelerometer Fault (Signal out of Range)
Mar 12, 2010 | 1991 Chevrolet Corvette
I have a 2008 Suzuki GSX-R 1000 an it boggs out at arround 2600 and 3000 rpm i don't know why
if the bike is unmodified and is fuel injected,there may be a fault in the ecu programme and probably the best solution to find the fault would be a trip to someone wioth a scan tool,they should be able to find the fault in minutes...cheeers
Jul 03, 2009 | 2007 Suzuki GSX-R 1000
Televison & Video Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
