Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Hot tub run on hgh for 7 mins or so then shuts off for 3 mins or so then comes back on when i try to turn it back on before the 3 mins is up hear a click
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Was your motor just replaced? I see this issue from time to time. It is caused by the pump overheating. You've either got clogged vents, very rare unless you have a rat problem in the spa, or your motor was replaced with one that has less hp.
ex. Either a spa repair company trying to make more money, or a home owner trying to save money deside to replace a 2.5 HP motor with a 1.5 HP motor with out changing the wet end. Now you have a smaller motor trying to push the origanal imperller. Result is motor overheats, thermal overload kicks the motor off, motor cools and comes back on to start the cycle over again.
Posted on Oct 26, 2013
I have a vitabath e600 tum shuts off after 45 min
sounds like the recirculation pump is overheating and tripping the breaker if the pump is ok could be heating element shorting out
Oct 01, 2014 | Qca Spas Jewel Series Topaz Plus Hot Tub
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
;turn coleman hottub on - flashes "pr" for a few min. then it shuts off
If your Coleman has Balboa electronics 'PR' is to notify you that it is in priming mode.
It could also be your pressure switch. On most tubs the pressure is mounted on the heater. If this switch is not reading correctly it could shut the spa down to prevent heater overheating.
Sep 18, 2012 | Pool & Spa
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
The dryer will run for 5 to 7 min then shut off come back in about 3 min it will run then the dryer will do it over and over again untill it will not trurn on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | GE DWSR463EGWW Electric Dryer
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Electrical Problem?Runs great then shuts down,let it sit runs fin
Sounds like the ECM is bad. This is a common problem, when the ECM gets hot there is a solder joint that seperates, it makes contact again once it cools down
Jun 17, 2009 | 1998 Plymouth Grand Voyager
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Power Working fine but keeps shutting off
Hi jenniferlahm,
This type problem usually shows it mean head when your motor is going bad. The motor will run for just a moment then it gets really hot and shuts off till cool. I bet when you start the dryer you hear a unusuall humm as the motor starts. If you are not hearing a hestating humm as it starts then the problem may be elsewhere. Other possible problems that casue this would be. the tub rollers. To check the rollers reach inside and try to turn the tub with your hand. you should be able to turn the tub. if not you may need new rollers, or pads. Good luck and I hope its not a bad motor, but if it is let me know and I can have you one there in no time.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Sep 24, 2008 | GE DBSR453EBWW Electric Dryer
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
100 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
