Question about John Deere Garden
I have a John Deere SRX95 mower. It does not shift from forward to neutral or reverse. It appears to be 'jammed' , and I cannot get the shifter to budge.
  • John Deere Master
  • 1,169 Answers
Check your transmission's shifter detent ball and spring. They probably have rusted.
You look at the IPL here >
SRX 95 Parts manual
Posted on Oct 22, 2013
4 Suggested Answers
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
philwalker78
  • 608 Answers
SOURCE: I have a L118 John
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
Posted on May 23, 2011
  • 3 Answers
SOURCE: After starting my John Deere LX277 the battery light goes on and the PTO won't engage. Water is filled in battery cells and the mower can go forward and reverse, but the blades won't turn. I
I would check all the safety switches to make sure they all work, and next check for continuity on your wires from the switch to the connector before the clutch.
Posted on Aug 09, 2012
John Deere 760-A scraper will not move forward but it will back up.
It is almost like a 4620 powershift farm tractor trans. When reverse goes clutch packs are shot. Sorry about that. Be sure the shift linkage is moving full range top to bottom.
Nov 21, 2016 | John Deere Garden
John Deere SRX75 Riding Mower unable to push when placed in neutral.
check that there is not a system that when in neutral , the park brake is not engaged
Oct 14, 2016 | John Deere Garden
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
Trouble shoot a John Deere lx 188 clutch?
Sounds like new belt is jammed or something is out of place. Turn by hand and find out where the problem is. You can tell where the belt is stuck or jammed. Pull the key before you mess with stuff underneath the unit. I installed my belt the wrong way on my unit and ruined a new belt and it would not shift.. The shifter rod could have been dislocated when you installed the belt also.
Jul 27, 2014 | John Deere Garden
How to fix John Deere 4600 stuck in reverse can't shift to forward gears?
The transmission/rear end will have to be taken apart. Most likely the keyway has broken and the gear is stuck in place.
May 14, 2014 | Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
It is a 1993 john deere 6100. there are 3 forwards and 1 reverse on one gear stick- 1, 2 ,3, r and the other is a, b ,c ,d ,e. the 1, 2,3, r gear stick has becoe loose and u cannot select gears 2 and 3. I...
The shifters do run cables to the transmission but you likely only need to remove the panel from the right side that covers the shift rods and then you can tighten the 13mm nut that brings the linkage rods together,the nut is on the shift lever not the range lever,Let me know how you make out and if i am wrong also let me know and i will dig deeper.
Sep 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
May 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
Mar 19, 2009 | Peg Perego John Deere Gator HPX
Garden Logo
362 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
