Question about General Electric WBSR3140GWW Top Load Washer
The motor of my GE washer (WBSR3140GWW) is not doing anything. It's flashing a green light continuously. I've tried the reset method recommended on GE's website but it doesn't seem to be doing anything. I've even tried to unplug the wires, wait, and repug; but it didn't do anything either. Any recomendations other than buying a new motor?
  • 283 Answers
Check the LED flashing against this chartthe motor of my GE washer (WBSR3140GWW) is not - 8791fcd7-3d9b-48de-9334-8882dae68f38.jpg
Posted on Nov 09, 2013
Ge washer tl1103pbwn
The washer uses a green light, which is the "Start" button, to indicate problems, and the flash pattern is a code to the type of problem. Two flashes means the washer's drain pump must be cleaned. Clumpy or poor-quality detergents can clog the drain pump. The user can attempt to fix the pump, but, If the problem continues, he must contact the GE customericon1.png service line for professional service.
Read more: http://www.ehow.com/how_12129638_troubleshoot-ge-washing-machine-green-light-flashing-two-times.html#ixzz2qLdypTQ0
Jan 13, 2014 | Washing Machines
My ge washer model wjsr4160g1ww will not spin or aggitate
A lot of times when that type GE Hydrowave washer does not spin/agitate it can simply be resolved by resetting the motor control board. This tip i wrote explains how to reset the motor inverter board and see if that resolves the problem with the washer. http://www1.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
If ya try restting it and it does not work watch at the little green light on that motor board and see how many times in a row it blinks and reply with that number of times it flashes and i will tell ya what error code is being displayed
GENE
Oct 23, 2011 | Washing Machines
Will not spin or agitate
Remove the front panel. Observe the motor flashes.
The motor blinks on and off all the time.
It blinks faster when running.
If a failure occurs you will get the following flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes bad motor
6 flashes locked motor check for objects between tub
7 flashes bad lid switch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes. If no light is visible you have a blown fuse built into the neutral side of the harness on the white/red wire.
themobilian_2813.jpgthemobilian_31.pngIf you see a small bubble in this black heat seal and the motor light is not on then the fuse within is blown replacement part is WH49X10041
What else do I have? Oh yeah how about the SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 12, 2011 | GE Profile WPRE6100G Top Load Washer
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
Aug 03, 2011 | General Electric WBSR3140GWW Top Load...
Washer will not spin or ajatate. I need to remove the front panel to see what up?
Use downwards force to relieve tension on the spring clips holding that front panel on.themobilian_1904.jpg
Video how to:
Once yall have the front panel removed yall will notice the motor has a green blinking light on it.
The motor blinks on and off all the time It blinks faster when running. That is normalment mon ami.
If it ain't acting right it will display flashes:
1 flash bad motor
5 flashes little green men (bad motor)
7 flashes bad lidswitch.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_26.pngthemobilian_27.png
Service manual and more HERE
Mar 16, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
All the lights light up, but washer won't fill when I push the start button. It is barely 3 years old. This happened before and then after I left it a while, when I pushed start it filled. I tried...
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You may need to do it several times before it resets. After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.
GE Hydrowave notes
Feb 10, 2011 | GE WWSE5240G
Hi, I overloaded my washer with towels. It hasn't fully drained (can hear water beneath the tub when you move it). I tried unplugging it for a minute, but the same problem presents itself. When start is...
The motor has a power inverter on top of it. Try and reset the motor by doing this:
Turn the washer off. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. It may take a few times. The motor has a green light on it that blinks. If it ain't acting right it will display flashes:
1 flash bad motor
5 flashes little green men bad motor
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_4.png If you see a liitle bubble in there then you know that dude is toast.
That fuse is: $7.50
Nov 29, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
Tub spins while in wash cycle
suspect what ge call a mode shifter pull front panel off by sliding putty knife along edge at each side and pressing clips front comes right off look on motor for a flashing green light (washer must be in operation) there are 2 wires in a single plug on motor these run back to transmission area with a volt/ohm meyer unplug and ck between the wires for continuity should be roughly 90 ohms if bad will not show any continuity
Oct 08, 2008 | GE WWSR3090TWW
GE WBSR3140GWW top load washer
bearing above transmission clutch need replacing..
Aug 25, 2008 | GE WBSR3140DW Top Load Washer
General Electric WBSR3140GWW Top Load Washer Logo
128 people viewed this question
Top General Electric Washing Machines Experts
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
