Question about Lionville® Medical
Lionville medication carts /Changed out button code system, can't excess cart
SOURCE: My Epson RX620 black cart absolutely will not print
Problem Solved!!!!
I bought the special cleaning cartridge as suggested and it worked very well. My RX620 is working like new!
Thanks!
Posted on Jul 11, 2008
SOURCE: Canon imagePROGRAF W6200
To reset the 'MT CARTRIDGE FULL SOON' error.
Enter Service mode Hold down the paper source and online button at the same time, hit the power button once.Continue to hold down the paper and online buttons until you see the printer name "Canon W6200" on the printers LCD display, then release the two buttons.The printer will initialize & enter service mode.
In service mode, scroll sideways until you see the 'Initialize' menu, scroll down to 'W-ink', and press enter. At this point I did something (scroll sideways and hit enter I think) and it came up with 'New W-ink Cart' Hit Enter to get '=New W-ink Cart' and Online to Accept. I powered down and back up, error all clear.
Posted on Jul 17, 2008
  • 11 Answers
SOURCE: error code 14 "no tuner cart"
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller
Posted on May 21, 2009
SOURCE: Hp 4600 color laser leaking
How to fix toner (Magenta) leak in HP4600...
I have read and tried everyone methods (dc controller, replacing toner, & adjust paper sheet type) of resolving toner leak. The answer to everyone's problem, is to " check & replace the the two black alienation plates (1.5" wide by 10" long, strips are vertical position, held by 2 phillips screws)" located on the back wall after removing all 4 toner cartridges. I found that the plate had cracked and didn't allow the toner to close properly. I temporary superglued the part back and order a new kit (Q3668-67925 $19.99 + s/h). Problem solved.
Posted on Mar 03, 2010
  • 34 Answers
SOURCE: 1999 ezgo golf cart.need to know the whole wireing
When you removed the batteries, a certain procedure MUST be followed. Key switch off, switch to tow position and shift lever in reverse. You must wait until the beeper unit sound dies out then remove the wire from the most NEGATIVE cable. Place in Neutral before installing new batteries. There is a specific sequence to putting the batteries in an EZ-GO cart. Failure to follow this procedure will kill the controller. The Key switch must be off and the maintenance/tow switch MUST be in the tow position when connecting the batteries. Any of the above will cause the controller to fail, due to improper discharge of the PRE-Charge capacitors.
Posted on Apr 22, 2010
Tip
Stocking a poratble medical cart
Medical carts are sets of trays and drawers that are on wheels and are available for immediate medical care in case of an emergency in the hospital. The medical cart can also be known as a crash cart. When properly stocked these carts can be the difference between life and death.
From one hospital to another the contents of the medical carts can vary, but for the most part they all have the same contents. These carts most often contain:
- Defibrillator or monitor
- Suction devices
- bag valve masks (BVMs) in various different sizes
- Advance Cardiac Life Support (ACLS) drugs like epinephrine
- Various drugs for common problems
- Drugs for rapid incubation and sedatives
- Various types of medical equipment like gloves, gauze and alcohol swabs
There are a lot more things that a medical cart can include, it is up to the medical facility to decide what will be on them. The main goal of a medical cart is to have as much of the necessary equipment that you will need in the case of an emergency.
To make sure that your cart is always properly stocked it would behoove of you to make a check list and a regular schedule to check and restock the carts. The schedule would depend on how often the carts are used, but generally after use they should be checked and restocked.
on Feb 02, 2014 | Medical
What is the maximum number of shelves in a medical cart?
It really depends on the company the manufacture the cart. It looks like the simple carts have about 3 wheels and the more sophisticated ones have drawers and shelves in different sizes. I saw one with 6 drawers:
http://www.metro.com/application/Carts
Apr 28, 2013 | Medical
I'm looking for a pink medical cart
Most of the medical carts I saw are white and some are blue. I couldn't see any pink or any other bright color. Maybe you can have it custome made or paint it yourself.
Can I buy a medical cart with removable wheels?
I think that most of the carts have removable wheels. It really depend on the cart you are looking for and which company manufactures it.
Here's an example of medical carts with what it seems as removable wheels:
http://www.rubbermaidhealthcare.com/products/Pages/Medication-Carts.aspx
Can you buy medical carts with computers attached?
Yes, medical carts come in lots of different varieties. I've seen carts with computers; with multiple levels of trays etc.
Take a look at the Capsa Solutions website, for some example of medical carts with computers;
http://www.capsasolutions.com/medication-carts/mobile-computing-medication-carts/
Jan 15, 2013 | Medical
Changed toner cart. do to void in middle of print
My whole day, today, was filled with dealing with bad toner carts.
Even new genuine ones from HP
6 service calls., 6 bad carts.
Aug 19, 2009 | HP LaserJet 5p Printer
Printer problem
Did you check the right placing of the ink cart? Is the support locked above the cart top?
After checking press menue then start mono (blue copy button). then fourtimes arrow-up button. machine will display maintenance and blicking. press 7 then 6 then 4. machine will be initialize the carts. press start mono (blue copy). machine will initialize the carts and will run some cleaning. After maintenance is shown again leave this mode by pressing 9 then 9. Do a test print.
If you cant see any bk insert another brand new cart and do the procedure again.
If trhere is still no bk the print head is clogged (because of generic ink??) and cant be cleaned any more! The ph has to be replaced by service personal!
Nov 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Medical Logo
246 people viewed this question
Top Lionville® Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Lionville® Medical Expert? Answer questions, earn points and help others
