Question about Frigidaire Dishwashers
Dish washer sprayer arm - Frigidaire Dishwashers
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon mdaksibley, thank you for your inquiry!
I'm not certain I understand your question or concern? What exactly is the issue your dishwasher is experiencing with the spray arms? Are the spray arms not staying in place? Are they broken or damage? May I please have the model number? The serial tag is typically located on the right side as you open the door. With this information I can better address the issue at hand. Thank you!
Posted on Oct 23, 2013
  • 62 Answers
SOURCE: KitchenAid KUDR01TJ - Top Sprayer came off
Sounds like something is broken. Have you tried the Bosh web site??? get the full model from the d'washer and type that in. the spigot that attach's the arm locks in or is part of the arm on most makes and models
Posted on Jan 03, 2008
  • 108 Answers
SOURCE: The bottom spray arm gets jammed in lower dish rack.
I would unscrew the cap and remove the whole thing... you might have something clogging one side, which makes more water come out on one side than another, causing it to wobble... or you may find something else causing the problem.
If there is a blockage, clearing it out can be tricky. really long pipe cleaners work well. Craft stores have them.
Posted on Jul 25, 2009
  • 118 Answers
SOURCE: GE Dish Washer GSD 2800
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Posted on Mar 01, 2011
heatman101
  • 43501 Answers
SOURCE: The water supply arm for middle sprayer is not
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Mar 03, 2011
  • 12 Answers
SOURCE: the top sprayer holes on sprayer arm are blocked, how does sprayer arm come apart to clear blockage?
The sprayer arm does not come apart. You have to remove the sprayer arm and use an object that fits in the holes to clear the blockage.
Posted on May 29, 2012
I had the same problem I own a Kenmore Elite dishwasher. Diverter motor needs to be replaced. The diverter motor is connected to a plate that controls the flow of water to each washer arm. When the plate moves it has holes that align to the proper tube that supplies water to a washer arm. When the diverter motor is broken it is unable to rotate and cannot direct flow of water. When this happens water will only be able to come out of one spray arm in my case the back sprayer or turbo wash. The diverter motor is located under the dish washer and the diverter plate is located under the bottom sprayer arm.
Dec 01, 2011 | Kenmore Dishwashers
The water supply arm for middle sprayer is not held in place by clip that is attached to bottom of dish rack. Does not meet up with water outlet on back of washer and also impedes movement of sprayer arm....
heatman101
Feb 11, 2011 | KitchenAid KUDS40CVSS Builtin Dishwasher
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher sprayer arms not working
you are not getting enough water inside of dishwasher.you can pour 1gal of water inside. to see if arm work better should be 3 or 4 inches of water in side of dishwasher. water valve maybe bad or dirty screen inside of valve.ck to see if enough water is in bottom of dishwasher.ck to see if flote switch in left front corner of dish washer is moving up and down.
Aug 12, 2009 | Kenmore Dishwashers
Jul 25, 2009 | Whirlpool Dishwashers
I used regular dish soap in washer and now the sprayer doesn't seem to be working. Is this an easy fix or did I blow it?
Do you mean liquid soap....as this will foam up considerably and cause a mess on your floor...like overflow problems...but even if it was this type of soap it would never inhibit the sprayer arm from working...you can take the sprayer arm off...sometimes a twist nut , sometimes a screw...and clean it as well as inspect it for debris obstructing the holes....other than that the sprayer arm is only there to direct the flow of water..the actual device that forces the water through the sprayer arm is the DW motor...does it run...do you have any water flow...is the DW filling with water...if so... or if not ..check these problems out and if everything checks out it may be a motor issue and a tech will need to be summoned....
I hope this helped to guide you.....thanks and good luck...The Fang
Mar 27, 2009 | Dishwashers
Ge quiet power 3 troubleshooting
First clean the sprayer arm of all debris. In the back of most dishwashers there is a screen on the bottom that is often full of junk, debris and other stuff from dishes not being scraped off.
Clean that screeen off.
Run vinegar (1 cup) for a full cycle to help break down the lime and other build ups.
Check sprayer arm for debris and other objects. carefully pick it out with a small needle or sometimes even a nail works.
Try running dishes again to see if this helps.
May 28, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dish not clean
Sprayer arms are clogged up.You can fix them by removing the arms and flushing them out in the sink
May 27, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Oct 22, 2007 | KitchenAid KUDR01TJ Dishwasher
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
