Question about Bosch Washing Machines
Not finishing the final minute of programme and touch buttons not responding
    Problem Solver:
  • 18 Answers
Had exactly the same problem myself recently. Turned out to be the drain pump had failed. Cheap replacement part from eSpares fixed it and is now fully working. Recommend you try giving them a call and they will probably advise you. If the machine is old you may want to change the carbon brushes on the motor as well. Bosch original parts are expensive. eSpares usually offer much cheaper alternatives as well.
Posted on Nov 19, 2013
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
My Nokia Supernova all of a sudden stopped working. None of the key is responding. On taking of the battery and re-inserting, I am able to restart it. It even asks to update date and time. But within a...
Try this trick this will help you
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link7210c file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gif Inside the interface at the> left top File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 13, 2011 | Nokia 7210
How do I change the time on my KX-T7730
You need to have the main phone,
1. Press the programme button
2. then *#1234
3. 000
4. SP-PHONE
then CONF (L) and/or FWD/DND (R)
finally press STORE/AUTO DIAL to finish
May 04, 2011 | Panasonic KX-T7730 Corded Phone
My LG Intellowasher does not finish programme.
Switch off and restart. Or circuit problem of the micro controller.
Mar 29, 2010 | Washing Machines
What does control lock mean?
This means that the machine will not respond to any controls and will have to finish its current programme completely before it will respond to any operator controls again. It is very useful to stop anyone changing the programme mid cycle. It also means that if the power is cut or you have a brown out that the machine will just carryon where it left off and finish the programme.
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Magellan GPS
Like a computer, it isn't "booting". Try phone support at Magellan.
Aug 23, 2008 | Magellan Maestro 4040 GPS Receiver
Finalize a CD
Put the cd back and press finalize...Wait a minute until finalizing time is displayed...After that press the pause button and it will start finalizing....It will count down until it is finished...
Jul 21, 2008 | HHB BurnIt CDR830 CD Recorder
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
