Question about Garden
Cobra lawn mower AND revs up - Garden
3 Suggested Answers
  • 205 Answers
SOURCE: lawn mower keeps looseing revs
Dump out the old fuel, and with the air filter off spray the inside of the carburetor with carb cleaner
Posted on Mar 22, 2009
  • 10865 Answers
SOURCE: have 24 hp kaw. engine on Cub lawn mower. At idle,
Hello. The usual cause of carb "hunting", is a weak governer spring. Although it might look fine it may not be and I would replace it. Another possible cause is a float problem. Finally it could also be the fuel filter or a chunk of debris in the carburator.
Posted on Jun 08, 2010
How do I adjust the rev on a talon eagle lawn mower revs are to high
check that the cable clip on the carby for the throttle has not allowed the outer cable case to move
readjust at the clip for idle speed so that the butterfly lever hits on the idle screw when the throttle is in the idle position
Dec 17, 2016 | Garden
I have trouble starting a toro walk behind mower
All,
I thought my carb was shot, so I replaced it. Still, start but no run (and had to use starting fluid). THEN!!! I noticed the spring to the "rev limiter" (just below and towards rear of carb) was not "tight". The stupid bracket that holds the end of that spring had been bent down ~1/16" and that caused all this heartache. CHECK YOUR REV LIMITER!!!
Aug 18, 2014 | Toro Power Lawn Mower
M48a wont rev
Check cable that is not loose when you adjust power or check that there's nothing rapped around the blades could decrease the power it's supposed to give when blade is spinning
Jan 03, 2014 | Garden
Talon mower wont rev
may have to bend arm where governor spring goes
Jun 10, 2013 | Talon Rotary Lawn Mower
Speed of the lawn mower governor is missadjusted
The engine revs are turned down to make the machine noise compliant, increasing the revs will greatly increase the noise, the engine revs shouold not realy be increased, however a dealer with a suitable engine taco may do it for you, it is very important not too over speed the engine or it will self destruct,
Apr 11, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
How to increase the land speed
bigger back wheels,otherwise you cant,unless you increase engine revs.should be about 3600 revs
Jul 04, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Cub cadet hydrostatic transmission new lawn mower, hydro growls pretty bad when taking off, is this normal for the 1045 or 2045 series?
check the hyro oil level is up to the correct mark. but some hydro units make a noise if you set off on full revs quite rapidly
Jun 11, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Have 24 hp kaw. engine on Cub lawn mower. At idle, engine is erratic, revs, then slows, revs, then slows.
Jun 08, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Lawn mower keeps looseing revs, it will keep going back and forth from full revs to about half revs.
Mar 22, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
