Question about Honeywell HM512DG115 TrueSTEAM 12-gallon Humidifier w/ TrueIAQ
Were do I mount the mounting plate above or below
Were do I mount the mounting plate above or below a coil
  • 66 Answers
Above so you are not steaming the coil which could solidify dust on coil.
Posted on Nov 08, 2013
Wiring for Honeywell H46C1166 - Dehumidistat, 24/120/240 Vac Wall-Mounted
Suggest you people READ the question before giving BS answers !!!!!!!!!!
Jul 22, 2012 | Honeywell H46C1166 - Dehumidistat,...
How close to heating coils to mount aprilaire 700
Hi google your humidifier can down load how to fix this in correct postion
Jan 22, 2010 | Aprilaire 700 Humidifier
Dry house with furnace mounted humdifier
Is the furnace fan set on auto or on. You will get better humidity if you keep the fan on. It won't add much to your electric bill because many of the newer furnaces operate the fan on DC voltage. Try it!
Jan 16, 2010 | Aprilaire 700 Humidifier
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
I have an aprilaire 760 that leaks water from bottom of case, I put new filter, cleaned all parts but I have the feeling that the fan is going in the wrong direction. Weird? Does anyone know what is wrong
Could use a little more info, but check this
These guys like to sit level and have all the parts in correctly. Double check that its is mounted level. When you change a filter on them the has to go in the exact way it came out and the plates with the tube have to line up just so. The filter has to also sit level so the water can trickle in the holes on top properly. That top bracket has to be sitting on the filter properly. Hope that helps
Mar 05, 2009 | Aprilaire 700 Humidifier
Aprilaire
Commonly outdoor wood boilers use a hot water coil mounted in the ductwork above your furnace. In this application the Ruud furnace is still using its blower assembly to circulate the warm air from the boiler to your home. If this is the case. Have your heating guy install a #50 relay on the furnaces blower motor to activate your much needed humidifier. If this is not the case and your Ruud furnace is totally independent of the boiler. Still install the #50 relay in the furnace and manualy activate the fan only feature on your thermostat.
Good luck
HVAC Teacher
Feb 21, 2009 | Aprilaire 600 Humidifier
Aprilaire 500A Do I need 24v transformer
if the funace has the 24 V you should use that but test it first with a call for heat to make sure it is 24 and not 120 coming out of that terminal!!!!!
Mount on cold air side with the bipass going to the supply.
Jan 17, 2009 | Aprilaire 700 Humidifier
Not getting enough humidity in the air
There are 3 things to check on the humidifier. Check the metal mesh screen, is it wet after the humidistat is call? If it is dry the water solenoid my not be opening or the nozzle is plugged. The circulating fan blows air through the wet screen to add humidity. Does the fan spin when the humidistat is calling? There is an intake and exhaust on the humidifier. Check that the metal was cut out properly when the humidifier was installed to allow air to feely circulate?
Mar 06, 2007 | Aprilaire 600 Humidifier
Honeywell HM512DG115 TrueSTEAM 12-gallon Humidifier w/ TrueIAQ Logo
42 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
