Question about i-mate JAM Pocket PC
Change language i want to change the language of my poket-pc from spanich to french
  • 2 more comments
  • Anonymous Feb 23, 2008
    it not cahange
  • yussmann Mar 13, 2008
    how do i change language from chines to english on my pocket pc
  • spblueangle Jun 28, 2008
    i need to change my language from french to english
  • Anonymous Jun 30, 2008
    hllo, i have to changed language from arebic to english. please send me solution.
  • 102 Answers
You have to download the "French Language ROM" and flash your i-mate with it. First Step: You need to download the latest ROM (English version!!!). http://www.clubimate.com/Support/ma_cdlsku2_arb_10300_141_10100_ship.exe After download run it. When you see a screen with "welcome to device software update utility", do nothing and go to your TEMP directory of windows. I you don't know where to look do a search for this file name: MaUpgradeUt.exe When you have located the directory that hold this file copy the complete contents, 8 files. To a directory on your PC eg: c:\jam Then cancel/close the "welcome to device software update utility" Second step: You need to find out the Operator code and language of you device. FRE for French Third Step: Download xda3nbftool.exe, and put it in the same directory as the 8 ROM files. Fourth Step: Build a batch file, name it change.bat or whatever you like in the directory where you put ROM files. Paste the following in it: ------------------------------- paste the data below ------------------------ xda3nbftool -x ms_.nbf ms_.nba 0x20040522 xda3nbftool -x nk.nbf nk.nba 0x20040521 xda3nbftool -x radio_.nbf radio_.nba 0x20040523 xda3nbftool -so T-MOB101 -sl WWE ms_.nba xda3nbftool -so T-MOB101 -sl WWE nk.nba xda3nbftool -so T-MOB101 -sl WWE radio_.nba xda3nbftool -c -u NK.nba xda3nbftool -c -u ms_.nba xda3nbftool -c -u Radio_.nba xda3nbftool -x ms_.nba ms_.nbf 0x20040522 xda3nbftool -x nk.nba nk.nbf 0x20040521 xda3nbftool -x radio_.nba radio_.nbf 0x20040523 del *.nba --------------------- paste the data above -------------------- This data is for a MDA Compact from T-mobile, with a UK language. If you have a German Language change the WWE to GER in the file. Fifth Step: Go to a Command Promt and change to the directory you have places all the files in. Then run your batch file. It give's some errors maybe about a password but ignore those, it works ! Sixth step: Run the MaUpgradeUt.exe program in the directory, it should start the UPGRADE. If not then you have not changed the language or operator code sucsesfully. Last step: If you have reset your device after the upgrade, be sure to skid the Extended ROM install. Install the apps you need manualy from the EXT-Rom. Some tips: If you want to find out your Operator Code and Language of you device: In the directory you should have a file called: GetDeviceData.exe copy this file to your device. On the device run it, it looks like it does not work but that is fine! Now go with you PC to your windows directory on your device. You should find a file called DeviceData.txt there. Copy it to your PC and open it with notepad. You should see something like this: --------------------------------------------------------------------------------- PM10A 0 A WWE E T-MOB101 1.01.00 0 0 1.03.141 1.00.10 WWE ----------------------------------------------------------------------------- The PM10A is the Device code The WWE stands for English language, if you have a different language it hould say so. German would be GER. The T-MOB101 is the Operator code. If you have different info there use it for the batch file. Language an operator code. Good luck everybody !!! And I will try to provide more info if needed !
Posted on Sep 27, 2007
SOURCE:
Tip
Change your keyboard latout
<span> Windows 7 or Windows Vista <ol> <li>Click <span>Start </span>, type <span>intl.cpl</span> in the Start Search</b> box, and then press ENTER.</li> <li>On the Keyboards and Language</b> tab, click Change keyboards</b>.</li> <li>Click Add</b>.</li> <li>Expand the language that you want. For example, expand French (Canada).</li> <li>Expand Keyboard list</b>, click to select the Canadian French</b> check box, and then clickOK</b>.</li> <li>In the options</b>, click View Layout</b> to compare the layout with the actual keyboard.</li> <li>In the Default input language</b> list, click French (Canada) - Canadian French</b>, and then click OK</b> two times.</li> <li>In the Regional and Language Options</b> dialog box, click OK</b>. <b>Note</b> The Language</b> bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.</li> <li>Click the Language</b> bar, and then click FR French (Canada)</b>.</li></ol></span>
on May 02, 2011 | Computers & Internet
I want to cange the lenguage from arabic to Spanich
Windows 7 only.
You need to install the language pack from Windows update.
If already installed? To change in Windows, go to Start > Search and type Change display language. Choose from list.
Dec 10, 2012 | Computers & Internet
How can i change the french language to english language because our laptop was a french language and i dont know how make it english
Go into Control Panel, select Region and Language, choose a display language by installing English first.
You may need your Windows Installation Disc!
Oct 17, 2010 | Acer Computers & Internet
How do I change from French keyboard?
Start / Settings / Control Panel / Regional and language options, check you have the language you want in there, then remove the additional (French) language.
This assumes you're running Windows XP. Vista or Windows 7 will be similar.
Dec 11, 2009 | Acer Aspire 4530-5889 Notebook PC
MY LAP TOP IS IN SPANICH IWANT IT IN ENGLISH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To change the whole system language you should install newer service pack with different language.
If you have XP SP2 in Spanish and want to have it in Eng, you will have to download SP3 in Eng, change someregistry keys (go to KEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Nls\Language registry key, and then change the value date for “Default” and “InstallLanguage” registry value from 0409 to 0410) and you'll be able to install it in Eng.
Resume:
1.Go to start
2. Press run
3. Type Regedit
4. Go to HKEY_LOCAL_MACHINE\ go to "SYSTEM" \ go to "ControlSet001" \ go to "Control"\ go to "Nls" go to " languages"
5. Change the Default” and “InstallLanguage” (first and last in the list) to 0409 [for you.S english, for other codes look down in the thread],
6. Download and install Sp3 for xp in English
7. Restart computer.
8. Be happy for it works.
Thanks for using fixya…good luck and don’t forget to rate this…
cheers
Jan 09, 2009 | Fujitsu Siemens Computers & Internet
Changing language
Hello
You cant change your language on your laptop true control panel, you need to reformat your laptop in the English language. the options in control panel is just for your regional settings and keyboard settings and so on.
only OS that you can change language in is the Vista Ultimate and then you need to install a language pack.
Oct 14, 2008 | Toshiba Satellite A100-S8111TD Notebook
Language
go to control panel and select regional and language option go to administrative and open change system locale select french and restart you laptop
Sep 30, 2008 | Dell Inspiron 1501 Notebook
Changed language system mobil
i want change my phone hp hw hp 6515 language change
Jul 30, 2008 | HP iPAQ hw6515 Pocket PC
Language,
I have the uniden cordless 6.0, series 1580. I mistakedly set the wrong language. How do I set it back to english?
May 30, 2008 | Lands Phones
i-mate JAM Pocket PC Logo
950 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
