Question about Pramac Generator 5000 Watt Subaru EX27 Engine S5000 DLX 04888
Manual for Pramac Generator 5000 Watt Subaru EX27 Engine S5000
  • 24 Answers
SOURCE: low voltage
Adjust engine speed
Posted on Sep 18, 2009
SOURCE: portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Posted on Mar 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
Posted on Jun 26, 2010
  • 152 Answers
SOURCE: I have a new Pramac 12500 watt generator, electric
It may have a seperate starter button
Posted on Dec 11, 2010
  • 185 Answers
SOURCE: I am looking for a repair/users manual for a 5000
Hi, you can try these sites, they have one for sale.
http://www.m-and-d.com/GEN-47361.html
http://generatorpartsdirect.com/manual6247-8.aspx
Posted on Mar 15, 2011
What is causing subaru portable generator to overrev?
Could be the return spring on the regulator has come off.
Oct 05, 2014 | Pramac Generator 5000 Watt Subaru EX27...
Fuel shut valve detached from bottom off fuel tank where it appears to have been glued on. How to reattach?
most have a rubber grommet that goes in the hole in the bottom of the tank and the shut off valve goes in the center
Aug 27, 2012 | Pramac Generator 5000 Watt Subaru EX27...
Valve is sticking
TRY SOME LUCAS ENGINE OIL IT WILL HELP WITH THE STUCK VALVE!
Dec 11, 2010 | Pramac Honda 5000 Watt Generator
How to change oil and what kind to use on a es 5000 generator
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Mar 23, 2009 | Pramac Storm 5000 Watt Generator
Oil change
There are two 14mm bolts on both sides (lower) of the motor. Unscrew one or both and drain the oil....Replace with sae 30 or 10w30 oil and should take almost a quart. (Put the bolts back in and tork slightly.) Check oil level.
Jan 11, 2009 | Pramac Storm 5000 Watt Generator
Pramac Generator 5000 Watt Subaru EX27 Engine S5000 DLX 04888 Logo
70 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Dinesh Nagal
Level 1 Expert
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
