Question about Rheem 13PJL42A01/RHLLHM4821JA 3.5 Ton 14 SEER R410a Heat Pump
My heat pump makes a aloud buzzing noise when turned on. It sounds like a warning buzzer on a dryer. We had this installed on 8-3-2013, and this is the first time it has been turned on.
  • 52 Answers
It's the contactor inside the service panel on the heat pump. Contactor might be faulty.
Posted on Oct 20, 2013
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Buzzing noise ft
Warning buzzer. Unplug and try resetting system
Oct 05, 2013 | Magic Chef Chest Freezer MCCF5WBX
Can i silence the parking brake warning buzzer till i take vehicle to dealer for repair
yes,wont hurt anything,search down by the sound of where the noise of the little bing or buzz sound is coming from and just unplug the harness.
Mar 05, 2013 | 2006 Volkswagen Passat
Turning the beep off?
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. Step2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device. Step3Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels. Step4Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jan 11, 2009 | GE Profile DPXH46EA Electric Dryer
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Warning buzzer
while the key is on and its making the noise look under the dash and fing the box thats making the buzzing sound. unplug the litle box and discard. you dont need it and it wont hurt anything if its not there. thats a problem on those fords with that box
May 21, 2008 | 1989 Ford Bronco II
Rheem 13PJL42A01/RHLLHM4821JA 3.5 Ton 14 SEER R410a Heat Pump Logo
127 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
