Question about Blade Tajima LC - 560 3/4" 8 Pt Auto Lock Snap Knife
How do you change the blade in a tajima lc-560
Tajima Tmex C-1201 won't light up ?
I went google and typed in --workshop manual for tajima tmex c-1201 sewing machine -- and found many pages with pdf downloads for repair manuals and workshop manuals
do that and find the right site for you and down load the workshop manual and that may be a way of fixing your machine
Sep 30, 2015 | Sewing Machines
How to adjust trimmer on tajima tumx
WIll need more information about what you are trying to adjust?
Machine functions a mechanical cut, but the thread wasn't cut?
Cutter has timing to be set or replace the fixed blade. are two basic possibilities. I need to know what it's doing cut wise? to know what to adjust.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 19, 2014 | Sewing Machines
Tajima c1501 axes code
Can you be more specific? Are you getting an axis code on the display? If so, what number is it?
Apr 19, 2014 | Tajima Drills
Attach your security device (1) tajima solution
attach your security device (1) tajima
Oct 08, 2013 | Computers & Internet
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
Jul 15, 2013 | Sewing Machines
I have a 28-560 can not tighten blade, new blade 82 and new rubber on wheels blade rubbs against switchs
Then you either need a blade shorter than 82" or the blade that you think is 82" is actually longer than that. It is also possible that the new tires you put on are a little thinner than the ones you took off.
Aug 04, 2012 | Delta Urethane Tires For 28-560 3 Tire Set...
How can I fix this error 3D7 in tajima
how to remove error 3d7 for tajima tmfd machine
Oct 27, 2010 | Tajima Drills
Hi I have a TEK Phaser 560 Printer that displays Error 32-"Imaging unit error" after PC sends print command and 560 tries to start printing. I had problems to pull out the Imaging unit as well, because the...
There's a solenoid under the control board that actuates a stop for the cleaning blade shaft. The open cell foam the factory used to quiet the noise deteriorates with time leaving a sticky residue from the double sided tape.
Pick all the residue off and clean both the solenoid shaft and the metal plate. If you're concerned about noise, put some electrician's tape on the plate. But you might be going in for that falling off down the road. :p
Nov 22, 2009 | Tektronix Refurbished Phaser 560 Color...
Blade Tajima LC - 560 3/4" 8 Pt Auto Lock Snap  Knife Logo
19 people viewed this question
Top Blade Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Blade Measuring Tool and Sensor Expert? Answer questions, earn points and help others
