Question about Radio Communications
TV ears one of the ears broke off form the transmitter. Wiring still intact
    Sergeant:
    Champion:
  • 263 Answers
Just use strong glue,Enough.
Posted on Oct 20, 2013
What wireless headphones are compatible with this TV?
any if not all, depends how much you want to pay. honestly, i'm not looking at the specs of your tv, but requirements: headphone out, or other audio out. the transmitter of the wireless headphones must match to one of those outputs. an adapter plug (image attached) is needed if transmitter can not be plugged directly into the headphone jack, the other end should match the transmitter plug.
https://www.google.com/search?q=mini+audio++plug+sizes&tbm=isch&imgil=fPgr9IHEKPb_PM%253A%253BrnA4P7_50b75CM%253Bhttp%25253A%25252F%25252Fwiki.robotz.com%25252Findex.php%25252FTRS_Phono_Plug&source=iu&pf=m&fir=fPgr9IHEKPb_PM%253A%252CrnA4P7_50b75CM%252C_&biw=1093&bih=710&usg=__Z31GOX6R8jYwB7fwgppqyciLVoY%3D#imgrc=fPgr9IHEKPb_PM%3A&usg=__Z31GOX6R8jYwB7fwgppqyciLVoY%3D
Oct 12, 2015 | Wharfedale Televison & Video
I have a sennheiser 300 iem g2 transmitter. Last night at a gig i was hearing some high pitched feedback through my in ears depending on where i was standing. Also the low battery light was on even wi
  1. "Feedback" might have been intermodulation with another RF frequency. Make sure to use Sennheiser's frequency finder, or something similar, to determine what TV channels are clear. If you're using more than one transmitter, make sure they're all using the same channel bank.
  2. The low bat/on indicator should be on solid if battery is good; and flashing if the battery is low.
Oct 05, 2014 | Audio Players & Recorders
Can beats s450 be connected to any soundbar?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
Sep 27, 2014 | Beats By Dr Dre - Wireless Bluetooth...
Sanyo hdtv model do 42647. 1080P tv
TV rabbit ears are for analog TV settings. You need an analog TV transmitter very close to the TV to get any good reception. Otherwise you need an antenna with more gain and more height to receive any analog TV transmitters in your area.
Aug 16, 2014 | Sanyo Televison & Video
How can I repair my Beats Mixr headphone in which one of the ear is not working ?
Presumably this is a wiring problem, for one of two reasons. If you look at the RCA plug that you use to hook into your stereo, you will see two black bands on it - one band for each signal - left or right. If there isn't a good connection, often you won't get sound in both earpieces. First try inserting the plug into your equipment part way, or rotating it carefully, to see if you can get both ears working. If that doesn't work, then the problem is either the wire for whatever ear is not working, not being connected properly at the RCA plug itself, or at the ear in question. You can unscrew the plastic cover on the RCA plug to see the wiring connection. But if the connection is bad at the actual earpiece, I would suggest returning the headphones, rather than taking them apart. Good luck.
May 23, 2014 | Beats By Dr Dre MIXR Black Over-Ear...
All I get is static when I use my T V Ears. Everything hooked up properly, have new battery. What's wrong?
Hook up your TV cable to Bell , Rogers , or satelite box , make sure cable is connected good.
Feb 27, 2012 | TV Ears 10241 Professional Listening...
Power lumbar not working in buick rainier
The drive nut may have broken loose or just broke. Short of opening the seat upholstery there is not much that can be done. At least since you are hearing the motor, the wiring should fine. It uses the same fundamentals as the seat positioning mechanism uses.
An upholstery shop might be your best bet to get the upholstery covering off intact with minimal damage so the mechanism itself can be reworked/repaired and seat frame repaired as needed.
The problem with cleaning solvents or spray lubricants is the potential for the foam seat form to get damaged- or worse- permanent smell.
Feb 11, 2012 | Buick Rainier Cars & Trucks
Screen broke
Screen broke? or did it crack? If so you need to buy a new TV. The replacement screen is worth more then cost of a new TV. If the screen is intact, you might new an inverter board.
Jan 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
I want to watch TV with rabbit ear antenna Olevia model 437S11
You would need to purchase a digital transmitter box for the new digital signals if the tv does not have a digital tuner. You can pick one up at any local retail store, that has an electronic section.
Oct 22, 2010 | Olevia 332V LCD TV
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
