Question about Refrigerators
My refrigerator make noise from the ice build up
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
Need more info are you talking from an icemaker or is it not defrosting and its building up ice ,is it a self defrosting ?
Posted on Oct 20, 2013
4 Suggested Answers
  • 148 Answers
SOURCE: ice build up
defrost the freezer,a hairblower helps,the drain tube is blocked in the freezer,you have to let it fully defrost then restart,this is a common problem for all fridges,turn back on after done make sure you feel the air blowing into the fridge,if it does it again its more than likely the defrost timer
Posted on Jul 07, 2008
SOURCE: Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Posted on Jan 07, 2009
  • 13 Answers
SOURCE: refrigerator side problem
most likely has a low refrigerant level due to a slow leak.you can call for service and have them add some gas to the system and it could be ok for a long time or if they can locate and repair the leak,it would solve the problem.call a few service companies and explain the problem.Ask how much each option would cost and decide if the frig is worth it
Posted on Jun 01, 2010
LG model LFX259605B making a humming noise.
newer pure source filter wont fit my system different base where can I get parts to change over
Jan 10, 2014 | Refrigerators
Cracking sounds from top of refrigerator compartment of a 7 year old WSE6070WA
Had the problem in a similar fridge - the repair person said the noise was most likely the sound of ice build up being removed during defrost cycle and not to worry. Suggest you check the freezer temperature is not too cold and building up excess ice.
Oct 20, 2013 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Whirlpool refrigerator model ed5phexnloo loud noise & ice build up.
If this unit has a ice maker, when it fills the tray, water spills out around the fill tube. The water drips down and builds up around the fan over time. Need a drain line extension to slide over water line, should take care of issue.
Aug 18, 2012 | Whirlpool Refrigerators
GSH25JFRFWW evaporator fan makes loud deep noise at times
GE refrigerators have a faulty design, and so don't defrost completely, so ice builds up in the evaporator coils and on and in the evap. fan motor. Melting the ice will make the fridge more efficient, and the fan quiet again.
The slow, easy way to fix is take out all the food, unplug the fridge, leave doors open all day. Ice will melt, and all will be fine ... for a few months, until the ice builds up again. The fast way is here.
Nov 15, 2009 | GE Refrigerators
Loud noise from refrig.
The defrost timer is faulty. replace it asap.
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Noise on the ice maker
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Jan 05, 2009 | Samsung RS2630WW Side by Side Refrigerator
Drain line froze.
chestnutlee.
Dec 27, 2008 | GE Refrigerators
Refrigerator Buzzing
if my guess is correct, that buzzing sound could be coming from the evaporator fan touching the ice that builds up in the evaporator. if that is true, a quick remedy for the noise to disappear is to thaw the ice, unplugged it for a while but as ice builds up again, then the noise would come back. the original problem would be the defrost cycle not functioning well. will be in touch if my guess is correct. thanxs,
Feb 11, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
