Question about Sightmark 22 LR Laser Bore Sight
My sightmark laser boresight goes dim after a second or two. I've changed batteries, but the problem persists.
How do you boresight a Barnett Red Dot 3 crossbow scope?
I use a 22 cal rifle laser on mine , the 22 is nearest the same diameter to the bolts I use so I can lay laser right into same bolt bed on frame that bolt normally rests in , then bench rest bow and get into shooting position then adj scope to bring crosshairs/ reddot onto laser dot at white target board , try to adj at distance you'd comfortably take a shot at
Sep 07, 2015 | Optics
Suddently gone dark
Try to plug it in a different USB port. If the problem persist, try it on another computer or laptop. If it still makes the same problem, you will know it's because of the mouse.
Jan 05, 2014 | Microsoft Wireless Mouse 5000
It wont start working
Jan 05, 2014 | Microsoft Wireless Laser Mouse 5000
I've had my ti-86 for a very long time & recently it just quit working. I changed the AAA batteries & the back up battery & it will not come back on. Please help???!!!!
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Dec 02, 2011 | Texas Instruments TI-86 Calculator
My yukon sightmark sm650 rangefinder laser is not working.The golf shop sold me a "Parview LS650" after looking around the internet, it looks exactly like the sm650. To my question....the laser...
Take it apart by peeling away rubber cover and then remove two mounting screws. Carefully split cases and see where parts are arranged just in case they shift. Laser and lens frequently get jarred loose ESP in a golf cart environment. Place laser and lens if loose back in mounts and gluon in place with superglue or equivalent. Make sure to get no glue on lenses. Reassemble and it should be good to go again. Total time. Ten minutes maybe.
Jun 09, 2011 | Yukon SightMark SM650 Rangefinder
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
May 17, 2011 | Robotoolz RT-7210-1G Robolaser,...
Battery goes flat overnight replaced battery still goes flat overnight
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you use a car charger, use a wall plug instead and replace the battery again; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the backlight will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone, the ones that come with the phone can often ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway. Use the charger that came with your phone, the voltage/amps are not always just right if using a radio shack special.
Jun 30, 2009 | LG Prada KE850 Cellular Phone
Problem sighting bushnell lazer boresighter
If you are attempting to use a red laser in daylight, you have to wear special glasses to see it well. You may have to complete this project with less light, such as after dark, or indoors. Only green lasers will show up in daylight. If this is not helpful, then I suggest that you change the batteries to brand new ones that you are sure of. There is probably no adjustment possible. Best wishes for your safe shooting!
Jan 04, 2009 | Bushnell Velocity Speed Gun
Sightmark 22 LR Laser Bore Sight Logo
53 people viewed this question
Top Sightmark Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Sightmark Optic Expert? Answer questions, earn points and help others
