Question about Ovens
My tricity bendix oven is in good condition but 17 yrears old. The fan oven is not heating, the fan is turning, but sometimes makes a squeaky noise, and no heat is being generated. The other part of the oven are working ok. Is it worth having fixed considering the age?
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: oven trips out when turned on
You will to check the fan oven element, it has probably failed.
Disconnect and try , if no fuse blow, then replace element.
Plz rate this solution.
Thanks.
Posted on Dec 14, 2008
SOURCE: Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
Posted on May 25, 2010
SOURCE: tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Posted on Mar 24, 2011
Tricity Bendix SE556SV lower oven not reaching tempature, new element, themostat and fan
First need to see if supply voltage is correct.
Verify oven probe sensor to the thermostat Is working properly? (usually done by Ohm test)
Thermostast offer an option for calibration?
Also have you verified actual oven temperature with an external thermometer?
Jun 09, 2015 | Ovens
I have a Tricity Bendix Built in oven TBS749. I have problems when baking as previously tried and tested recipes do not bake properly with burning on the top but the inside not cooked. I had noticed that...
Have you tried to turn the oven on to preheat and observe that the upper and lower heating elements alternately go on and off? Could be that 1 of your elements is burnt out and need replaced.
May 02, 2017 | Ovens
My tricity bendix main oven (model S1510W) is not doing anything! The fan is not moving and it will not heat up. Do you know what the problem is likely to be?
Unfamiliar with your model but:
It is most likely a broken/burnt Selector switch (This switch is situated at the back of the same knob you turn to activate your Fan) Decent technicians will be able to rebuild this switch into a generic base switch (Can get this from most appliance spares departments), or you can even do it yourself - This is more likely to be the problem, as it is the selector switch that turns on both the fan & element on the oven.
Good Luck :-) - J.Q
Feb 16, 2011 | Ovens
Hope this helps.
May 25, 2010 | Ovens
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Tricity Bendix SIE504W oven overheating
I have had a similar problem in that the top oven was overheating getting hotter and hotter and have just got a replacement thermostat from Partmaster.co.uk. This is to fit a Tricity Bendix from Currys model number DSIE520 GR. The new one seems just like yours in that it has three lettered connectors A,B and C. With the part came a sheet stating that for a free standing appliance with NO timer (this what my cooker is) the connections to be made are : 2 on old part to A on new; F on old to B on new; G/H on old to C on new and the link from G/H and 6 on old to be removed or "severed". I haven't yet done this as its in my cottage which I'm going to this weekend. Good luck! James
Aug 11, 2009 | Electrolux Ovens
Oven trips out when turned on
Thanks.
Dec 14, 2008 | Ovens
Tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
May 07, 2008 | Ovens
Tricity bendix fan oven
Apr 07, 2008 | Ovens
Tricity president double oven
if this a uk model and less than 15 years old you can ring tricity,they should be able to supply you with a manual
www.tricity-bendix.co.uk
Mar 06, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
