Question about Home Security
How to stop dicon smoke alarm beeping
How to stop dicon smoke alarm from beeping when battery has been changed.
  • 2,113 Answers
All smoke alarms beep if the battery is too low. Getting a used battery isn't good enough for smoke alarms. Even getting a new battery from a dollar store (a cheap no name brand import store) will not do... it has to be the newest and it has to be alkaline. once you put it in... press the button for 10 seconds... first you will hear it's own alarm then you will hear the others attached to it in the whole system chime in (if you have that type) the alarm will now sit quietly.
Posted on Oct 20, 2013
Alarm went off without warning in the early morning.
When you said 27 years, you said a mouthful. The national fire code (NFPA 72) requires that all such smoke alarms be replaced every 10 years. Your detector is well beyond its reasonable life expectancy and needs to be replaced.
Mar 21, 2016 | Home
How do I stop smoke alarm from beeping
Smoke alarms beep in two different ways: it beeps continuously when smoke is present, and it beeps every so often (intermittently) when the battery needs to be replaced.
Feb 18, 2015 | Cars & Trucks
Fire alarm beeping after battery change
you need a good quality fresh battery, cheap or old batteries are not strong enough
Jun 27, 2014 | First Alert Brk / First Alert Smoke...
Stop beeping alarm
You need to change the batteries. Get the newest get alkaline once it is in it may still beep until you press the test button for 10 to 15 seconds to reset
Nov 26, 2013 | First Alert SA302 Dual System Smoke...
My alarm is testing multiple times a day
Check that the battery is installed the right way around. Most smoke alarms can only be tested manually (by pushing the button). If you are hearing a single beep every 50 or 60 seconds then this is the low battery indicator and this will sound if the battery is inserted the wrong way around. If the siren is actually sounding continually then your smoke alarm might be clogged with dust or other foreign matter. All smoke alarms should be replaced every 5 to 7 years as the components in them only have a limited life span.
Nov 10, 2013 | First Alert SCO7CN Battery Operated...
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Kidde pe 120 photoelectric sensor smoke alarm emits 3 "beeps" with a pause and then repeats until the 9vdc battery is removed. The house is not on fire and the 120vac power is connected. What might be the...
The 3 beeps, known as temporal pulse, is indicative of an alarm condition. If it stops without a battery, then the unit either does not have power or is otherwise defective.
Jun 03, 2010 | Kidde PE120 Hardwire with Battery Backup...
Kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Jan 28, 2010 | Kidde i12040 Hardwire Smoke Alarm with...
Home Security Logo
578 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
