Question about Saws
How to remove the brushes on the elu 174 mitre chop saw
thabrain
  • 76 Answers
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: Compound Mitre Saw Motor turning, spindle isnt.
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Posted on Aug 21, 2009
  • 8404 Answers
SOURCE: Compound mitre saw won't shut off unlss unplugged
Relace the switch.
I am presuming the lock button has not been inadvertently pressed ... Check that first.
The condition you deacrive is dangerous. Please fix it before you use it any more.
If you require additional assistance, let me know.
Otherwise, check RepairClonic.com for parts and technnical instruction from their crack crew.
Thanks for the opportunity to lend you a hand
a
Posted on Sep 26, 2009
  • 885 Answers
SOURCE: carbon brush has broken and is stuck in so i cannot put a new one in, on Einhell sliding mitre saw
If you cannot get the carbon pieces and/or spring out of the brush holder your only option is to take the saw apart and remove the armature. From there you can either push the carbon piece(s) through or out from the other side. It will also give you a better assessment of any damage caused to the brush holder and armature contacts.
Posted on Feb 27, 2012
Testimonial: "Thanks, I have taken the saw apart and pushed through the broken carbon brush. Thanks for the advice"
rowdy45176
  • 2176 Answers
SOURCE: macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Posted on Mar 01, 2012
Need brushes for mastercraft slidingdual-beveling compound mitre saw
get from any appliance repair shop
there are generic brushes available that can be filed to size
take your old brushes along as a sample as generally there will be brushes that will fit straight in
try e-bay--type in the search area-- brushes for electric saw motors --or some like search
Sep 07, 2016 | Saws
My elu flip saw shorts out when I flip it over from a table saw to the chop saw, it works fine as a table saw
There is a bridge rectifier its a little black round piece in the box of the red green switch that must be replaced i see you have got a gray or bleu ELU not a dw 743 i know this problem that is what i know buy a new rectifier or place 4 diodes 1n4007 in a bridge if you know how to do this to make AC to DC its only for the magnet switch and connect the 4 wires to it .
May 28, 2014 | Dewalt Dw743n 240V 250Mm Combination Saw
I have a Performance Power Tools PP1100MS mitre saw and i need to replace the blade but its not obvious how to do it and i have no manual.
Hi, I too have a performance power mitre saw pp1100ms and need to replace the brushes. I have the parts but no diagram...any advice please ????
Nov 10, 2013 | Saws
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
10'' delta mitre saw making bad noise when in use
Highly unlikely the armature would warp. Both front and rear armature bearings would be my first guess.
Jul 10, 2012 | Delta Chop Saw 3 Ph, 50/60 Hz,...
Carbon brush has broken and is stuck in so i cannot put a new one in, on Einhell sliding mitre saw
Feb 22, 2012 | Saws
Need a replacement m8 lefthand1.25 thread in 12.9 tensil for a elu chop saw
Depending on where you're located, sometimes specialty tool stores carry (or can order for you) spare parts for tools. You won't find it at a typical DIY type store like a Home Depot or B&Q warehouse type store but rather a tool store that outfits the trades. Try going back to the place you bought it perhaps?
Aug 13, 2011 | Saws
I casnt remove the centre nut from my c8fse chop saw
Hi, when I do this I insert a large screw driver into the blade saw to stop the blade turning, as you will need to turn the nut clockwise.
Aug 01, 2010 | Hitachi C8Fse Sliding Compound Mitre Saw...
I have an elu flip saw that works as atable saw but not as a drop saw is there a wiring diagram so i might trace through the fault
there is a cable that runs from in behind the drive belt and around and under to the main switch block . because of the flipping action it can open circuit . youllhave to check it with multi meter . good luck old but good machine.
Nov 15, 2009 | Saws
My ridgid mitre saw won't get up to speed after a year in storage
The brushes and the armature have probably oxidized a little. Remove the brushes and clean the contact end with a piece of sandpaper and re-install them. This should have you up and running again. The armature will clean off during use.
Sep 22, 2009 | Ridgid Reconditioned 12 In. Compound Miter...
Saws Logo
35 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
