Question about Smeg Dishwashers
Smeg dishwasher stuck on soak mode - Smeg Dishwashers
My smeg di 612ca dishwasher door will not shut.any ideas?
Check that nothing is protruding from inside of machine. If still won't shut check that nothing is stuck in the closing mechanism. As a last resort contact manufacturer or service agent.
Aug 11, 2014 | Smeg Dishwashers
Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
SMEG Dishwasher - Water fill level is too low
Hi, I found your problem stuck here from one year ago.
I will post my solution the same, as reference for you and more users with same problem, apologies.
Re: smeg dishwasher fails to fill with enough water to sucessfully wash. It does put some water in.. but nowhere near enough.
Before checking parts inside the machine, ensure that water is coming from the faucet at the back with regular pressure.
To start check the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is getting stuck then that is the problem.
If the water level is OK, then the responsible is usually the inlet valve, or clogged inlet lines.
From description it looks more like a faulty water level.
Mar 14, 2008 | Smeg CSU2001 Built-in Dishwasher
Timer Knob Smegdishwasher sa 620x
I have this same model Smeg dishwasher. 1 = Soak - pans and dishes awaiting completion of the load. 2 = Strong - Very dirty pans and dishes dirt dried on. 3 = Normal - Normally dirty pans and dishes. 4 = Rinse - Dishes requiring "refreshing". If you would like a full copy of the user manual, send your address to "brockjack@g-node.com.au" and I will photocopy our manual for you.
Oct 06, 2007 | Smeg CSU2001 Built-in Dishwasher
It's stuck on Bio...
Here is the link to the user manual, hopefully this solves your problem else please ask again; http://www.smegtech.com/site/smeg/pdf_libretti/19590097802-GB.pdf Hope this helps :)
Jun 25, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Smeg Dishwasher
you may have a foreign object stuck in the pump. it may well disappear with time and it is an aweful job to get at
May 22, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Help
We have a Smeg SA8605W which has had a similar problem 3 times in its short 3 month life. The problem with ours is that the control panel on the front pushes against a very brittle plastic frame to activate the micro switches. Because of the brittle nature the 'fingers' of plastic break off and either get stuck holding the machine in a set cycle or break off fully so nothing functions. Gaffa tape or Elastoplast is a simple solution.
Nov 08, 2006 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
78 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
