Question about Honeywell T6360b1028 Room Thermostat
Easy wiring diagrams - Honeywell T6360b1028 Room Thermostat
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
Wiring a Honeywell V8043E for two zones
Honeywell posts pdf manuals.
Google seArch Honeywell V8043E .pdf
Include .pdf in search parameter to find manual with wiring diagrams.
http://www.forwardthinking.honeywell.com/related_links/water/5000_series/install/95c_10932.pdf
Oct 26, 2012 | Honeywell V8043E1012 Zone Valve 3/4 Sweat,...
I need a wiring diagram for a ge 240 vac timer please
GE sells several timers rated for 240Volts.
Including the 15307 timer made by Tork, rated 208-277Volts, 40 amp, 60 Hz
Copy following link for wiring GE 240Volt timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Oct 18, 2012 | GE 15307 240 VAC 24-Hour Outdoor...
I need a wireing diagram for two elament electric water heater. Mine runs on 220 volt, my question is what about the common or white wire where do i hook it to or do I not need it when running a 220 circut
Links below show specific wiring diagrams and explain 240V with two hot wires vrs 120V with hot and neutral wires.
Then if you have more questions, add a comment and I will fill in blanks:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
First diagram will be for your water heater.
http://waterheatertimer.org/B220C.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Reliance & 40 Gal Electric Mobile Home...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
Sep 18, 2010 | Whirlpool Water Heaters
Honeywell T6360b1028 Room Thermostat Logo
23 people viewed this question
Top Honeywell Water Heaters Experts
paulcarew
Lawrence Oravetz
Steve
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
