Plded3257a-d proscan 32in led tv
    Top Expert:
  • Televison & ... Master
  • 73,698 Answers
What is the problem you faces with this TV? Provide more details please. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 20, 2013
3 Suggested Answers
  • 956 Answers
SOURCE: 47" Proscan LED TV Manual
What's your question, if missing, go on line type in specs of TV in a search engine and follow through. Happy surfing!
Posted on Dec 26, 2010
FSAhead2
  • 214 Answers
SOURCE: does the Proscan 47" LED
yes it does , if you are viewing the TV from the rear it is located in the back on the lower right , on the right side of the RCA's . here is a link to give you a visual , just wait for the manual to pop up .
http://www.managemylife.com/mmh/owner_manuals/15565/PROSCAN-LCD-Television-L1001098
Posted on Jan 28, 2011
My 32" ProScan plded3257a-b won't turn on. Red indicator light turns yellow when power button pushed. Is this bad news for this trusty companion?
Hello John West,
I just checked MY first recommended SPARES dealer
(link will be at bottom: "SHOPJIMMY" for stock... on your
ProScan plded3257a-b... They are out-of-stock
WHICH MEANS MY 1st GUESS is a popular GUESS.
Your main POWERBOARD is divided into specific power sections... MOST LIKELY... you could open your set and (I DO NOT recommend) be able to measure... the PRINTED voltages around the out-put points WRITTEN around ON the Printed Circuit Board... (but these boards are in-expensive and the risk of injury is not worth the POTENTIAL savings
(assuming you have the requisite skills & materials).
Always check your OWN BOARD NUMBERS...!!!
Never force any connections...!!
Take lots of pictures ... put EVERYTHING EXACTLY BACK.
My first and ALWAYS recommendation... always protect delicate SEMI-CONDUCTORS by wearing anti-static wrist straps... A tiny static spark you might not feel is sufficient to RUIN the diodes in your cars ALTERNATOR (honest... for reals).
Second serious precaution... Use shopjimmy, amazon, eBay or worse... Searspartsdirect.com... (at page bottom)
Never rely on anything but your OWN circuit board numbers.
Serious ELECTRONIC technicians always take STATIC PRECAUTIONS... and turn off the power (when-ever possible).
It is not improbable that the mainboard is your issue...
but compared to a "QUALIFIED" (good) home repair technician...
It is a mistake you can afford about 5 more times...
and if you can go BACK to your ORIGINAL FAILURE condition... you are doing fine (excellent start)...
Most "home technicians" aren't even good.
As far as I'm concerned... these packs are too cheap to recommend live power tests (YOU can get seriously ZAPPED)...
If the POWER BOARD does not immediately power up... I would suggest you assume 1 (one) of two (2) things...
1. Your "NEW" board is also bad (or you did not try to select "sources" when you installed it... (been there.. did that).
2. It was actually your MAIN-BOARD that needed to be replaced.
Buy one.... TRY IT.
Hey... if you like the set... so you end up with a couple of spare packs... properly handled & stored they will only appreciate in value).
Ill-advised activity... (voltage testing)
If you own a decent volt meter...
and you can look CLOSELY at the TEST POINTS... YOUR POWER BOARD voltages are printed on the circuit-board OUTPUTS:
Just keep in mind... you can get hurt... while causing more damage... with careless handling!!
Take photos... Work safely... Check your numbers and
ALWAYS wear ESD (static) wrist bands...
TV Parts Universal TV Stands DLP Chips ShopJimmy
Water Filters Lawn Garden Appliance Parts
Nov 16, 2016 | Proscan PLDED3257A 32" LED TV 60 Hz, HDTV
No picture has sound on 32in combo proscan
Make sure the antenna or cable wire is firmly connected on the rear panel of the TV. Then click the Settings button your remote control and check if someone accidently selected "Picture Off" mode and undo that setting.
Nov 04, 2014 | Televison & Video
How do you repair or replace powersupply on proscan modwl plded3273a
Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Oct 02, 2014 | Proscan PLDED3257A 32" LED TV 60 Hz, HDTV
Can I default my 32in vizio tv. I am stuck in spanish and want to go back to english?
select MENU on your tv remote.
choose settings
select language
Choose English
Apr 25, 2014 | Vizio M320NV 32in 1080p LED HDTV and Mount
What is the best picture settings for my proscan 32in led hdtv?
16:9 ratio. 1080P will be for an HD box from your cable provider with an HDMI cable.
Dec 29, 2012 | Televison & Video
RCA Proscan TV
I am so sorry, but that board is Way out of production. You might try service forums for Thompson or Proscan. What kind of problem is there with the old one?
Mar 09, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
