Question about Pyle Pro PTA1000 1000 Watt DJ Amplifier
My Pyle amp cut off and will not turn on - Pyle Pro PTA1000 1000 Watt DJ Amplifier
    Sergeant:
    Champion:
  • 272 Answers
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Posted on Oct 21, 2013
PYLE PTA 3000 cut off and will not come on
Will it no longer come on anymore, or does it take multiple tries before it comes on? If it has stopped coming on all together, you may have blown a component on the unit.
Oct 20, 2013 | Pyle Pro Ppa300 3000 Watt 2 Channel Dj...
Pyle PLTAB8 Car Component System, Lights will not turn off. Help
Sounds like he did not wire a remote line from your radio to the amplifier, if he put a 12v from the battery to the amp and the remote spot on the amp then it will not turn off, you will need to either wore a toggle switch to the remote so you can turn it off manually or check the back of your radio for a remote line or splice a remote line from the accessory power supply on your radio so the amp will turn on when the radio is on
Feb 06, 2012 | Pyle PLTAB8 Car Component System
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
I have a 10" pyle
+ to + but if your amp shuts off and turns on switch it to + to -
May 05, 2011 | Pyle Car Audio & Video
I have Pyle PLTDN71, everything is wired properly , but it only plays music for 3 secs and cuts off. The problem is repeated everytime the unit or car is restarted... anyone ???
u probably connected ur power or constant to ur lights. if ur lights turn on ur accesry switch and than ur ight if ur stereo turns off thanu have tosee witch wire is connected wrong
Jul 09, 2009 | Pyle PLTDN71 Car Video Player
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Rockford amp cut out
Disconnect all speaker wires from the speaker terminals of the amp and disconnect the RCAs. Replace the 30 amp fuse with a 15 amp fuse. If you turn it on and it blows the fuse, it's likely that it has shorted output transistors. If that's the case, you need to have the amp repaired.
Dec 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
My amp makes a constant tone
its says 800 watt and you say 20 watt bass amp?? Is this for a car or a guitar??
May 24, 2006 | Pyle 800W GUITAR AMP Car Audio Amplifier
Pyle Pro PTA1000 1000 Watt DJ Amplifier Logo
152 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
