Question about Bernina Sewing Machines
1080 manual the material grippers under the stich plate are not coming through the holes so will not move the material along. They move back & forth but are too low to grip. What's the problem?
  • Bernina Master
  • 7,365 Answers
SewExpress
  • 41 Answers
SOURCE: My machine Bernina 830 does not run.
Hi Rose Mary,
I'm assuming you are talking about the original Bernina 830 (their newest machine is also an 830!)
If you've not had your machine professionally serviced in awhile, it could be as simple as a good, thorough cleaning and adjusting. Your machine should be professionally serviced about every 1-2 years....not a bargain service that blows out the dust and puts oil on the hook, but a service that checks all the gears for wear, adjustments, hook timing, feed timing, grease for the gears (if required), removes lint build-up deep in the machine - very thorough.
There are various gears in the 830 that control these functions. It sounds as if one of the gears may be either broken or jammed. Unfortunately, unless you are trained in machine repair, this isn't something you should attempt. When gears are replaced or adjusted, generally the timing of the machine must be reset as well.
We would recommend that you take your Bernina to your nearest authorized Bernina dealer (they'll be trained on your specific machine and have easy access to any parts that may be needed).
If you do not know a dealer in your area, you can search on the Bernina website.
The original Bernina 830 was one of the greatest models Bernina has made and is well worth putting the money into keeping it running. Great machine!
Hope this helps narrow down what may be happening.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Nov 29, 2008
  • 6 Answers
SOURCE: I have an older 1998 portable Bernina with feeder problems.
Maybe just working that bullet shaped part will get it going. If it's a 930, you need to turn the handwheel to make the dogs get back into 'operational mode' after you move the knob.
Sometimes the mechanism is stuck behind the knob. Don't force the knob. It's possible to take the motor casing off and work it loose. Use TriFlow lubricant (small black bottle Sherwin-Williams) and leave for a while. Push gently with a pencil. Whatever you do, don't whack it with a hammer, like some folks say. It likely needs to move in the other direction (if it's stuck in 'regular' mode) i.e. towards the needle end.
Posted on Jan 18, 2009
  • 76 Answers
SOURCE: feeddog only moves up and down instead of in a
look in your manual there is a switch, slide or something that will move the feed dog back to the original position, you have it in the free hand mode lij=ke for free hand embroidering or darning
Posted on Aug 27, 2009
  • 1456 Answers
SOURCE: The thread keeps tangling and
Hello
The first will be bobbin winding. When finished, make sure the bobbin is placed into the bobbin case so the thread is feeding counter clockwise and be sure the thread is slipped through the guide on the side of the bobbin case. Pull out a couple inches to make sure.
Always be sure the presser foot is up when threading the sewing machine or this might cause the thread to tangle
After threading, hold onto the end of the upper thread then lower and raise the needle so it picks up the bobbin thread. Take the ends of both threads to the back of the machine and ensure that the bobbin thread has not popped out of the guide on the bobbin case.
Drop-in bobbins collect a lot of lint in the bobbin case and need frequent cleaning. The bobbin thread can sometimes pull out of the guide on the side of the bobbin case.
Make sure the tension is set according to the recommendations in the manual.
Place a folded scrap of fabric under the presser foot and lower the needle into the fabric. Stitch a few inches to see how the stitching looks. Do this test each time you change any of the settings.
If you have been sewing a fabric with a lot of nap (such as fleece) lint can accumulate in the bobbin case and surrounding area. Refer to the maintenance section and follow the instructions carefully to insure the correct placement of the bobbin case after cleaning.
If these steps do not solve the problem then the timing needs to be re-set and this means a trip to the shop.
Posted on Jan 03, 2011
SOURCE: my stiches keep missing a stich
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
if these suggestions don't help the the machine could be out of
time & the machine would need to be taken to a sewing machine
shop to be checked
Posted on Aug 06, 2012
I am trying to darn a hole for the first time. Can you tell me how to set the length of the stitch after I have pressed the reverse button
When you darn with a sewing machine, the operator regulates the stitch width and length by moving the fabric manually. The feed dogs are dropped below the needle plate (or covered with the needle plate cover in the accessory kit). A darning foot is attached to the machine. Then the operator manually moves the fabric back and forth and forward/backward while stitching.
Aug 18, 2017 | Sewing Machines
I started to sew and the needle does not move and just stitches in place.
does the plate under the presser foot move back and forth that is what moves the material some drop down when in certain modes . like darning or freehand quilting as I see no make I can not look your up anywhere .
Jul 21, 2015 | Sewing Machines
Singer xl1000 is locking up
Is your material beginning to go under the feed dog? If this appears to be the problem then try placing the needle on the right or left side of the needle plate while you sew. If your material is thin it will especially be a problem and stop the machine from movement. I hope this helps. If not then come back for some more help.
Nov 18, 2014 | Singer Quantum XL-1000 Computerized Sewing...
Feeds dogs are lowered even when in the up position
Check to see if there is a bunch of thread under the needle plate preventing the feed dogs from returning to run position.
This may mean having to take the needle plate off and really looking
Jul 29, 2012 | Brother CS-6000
I am looking for a instruction manual for a TOYOTA E&R CLASSIC LC-21 SEWING MACHINE.Ive moved house twice and the instructions have got lost in the removals somewhere along the line as the needle keeps...
try manualsonline.com/ also could be old thread, needle not threaded correctly, tension incorrect. incorrect needle for the material. Good luck
Dec 05, 2017 | Sewing Machines
I have a Finesse sewing machine and I was sewing some placemats but it suddenly stopped feeding the material although it keeps sewing (foot moves up and down). According to the book I have checked the...
Can you see the feed dogs moving?
un thread, raise the pressure foot then manually turn the flywheel towards you and watch the feed dogs (the teeth that move under the needle plate). If they are not moving around and coming up above the needle plate then one of two things:
either you've accidentially disengaged the feed dogs, check the manual for instructions to reengage, sometimes a knob, button or slide, often on the front base or around the back of the free arm.
If they are engaged but not moving up at all, then something has gone in the drive to them, usually a gear in the free arm area. In which case, take to the shop for repair.
Jul 01, 2011 | Sewing Machines
The material feed isn't working on the borrowed machine that I am using. Is there an adjustment? I have to feed the material by hand!
Are the feed dogs up? Can you see them moving?
Sew without fabric and you should see the feed dogs moving back and forth under the needle plate. There may be jammed threads in it if it is not moving. Not sure about your machine but most needles plates either flip up or can be unscrewed to check underneath for clogging.
Dec 18, 2010 | White Sewing Sewing Machines
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Singer 132K6 industrial machine
Make sure that the thread is under the tension spring then thread it throgh the hole in the spoolcase,push the spoolcase retainer over to hold it in then turn the balance wheel towards you to pick up the thread through the hole in the needle plate, pull both threads back and sew away. I can supply a manual for this machine if you want one.
Robert
Aug 25, 2008 | Sewing Machines
Sewing Machines Logo
152 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
