Question about Jenn-Air JMC7000 Microwave Oven
My JMC7000ADW microwave does not turn on and turntable does not turn, even though the counter with display is on and countdown starts as soon as you put time in it.
  • 2,113 Answers
Open it up and look for button shaped thermal cutoffs, test for continuity. Also look for burned wires and repair. The magnetron is the likely culprit so i don't expect you to find anything else. Also there is a belt that turns the turntable. Just replace the belt. I have always salvaged microwaves out of the garbage (prior to the new appliance recycling programs) and pilfered free parts out of them. 95% or more had good magnetrons so i throw them into a box for future repairs.
Posted on Oct 20, 2013
5 Suggested Answers
SOURCE: JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
Posted on Oct 11, 2008
  • 178 Answers
SOURCE: Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Posted on Sep 11, 2009
SOURCE: microwave stopped heating, lights & controll panel still work.
probably belt loose/broken, remove case to see.
Posted on Nov 19, 2011
walesarumi
  • 6993 Answers
SOURCE: JennAir JMC7000ADW Microwave Oven Turntable not turning
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Posted on Jan 05, 2012
What could be wrong with our jennair microwave model jmc7000adw? when you try to start it, you can hear a click like noise but nothing happens. display panel and buttons seem to work fine.
most likely a loose wire on the door switch.but I would recommend a trained repair as microwave ovens can be very dangerous to fix,.Adrian......
Jan 22, 2015 | Microwave Ovens
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
I cannot stop the DEMO
Demo Mode The Demo Mode is ideal for learning how to use the microwave oven. When set, functions can be entered without actually turning on the magnetron. The microwave oven light will come on, the fan will run, the countdown will run very quickly in the display, and the turntable will rotate. To Turn On/Off: The microwave oven and Timer must be off. Touch and hold TIMER SET/OFF for 5 seconds until 1 tone sounds. Repeat to turn off.
Jan 21, 2012 | Whirlpool Microwave Ovens
Good luck.
Dec 17, 2011 | Jenn-Air JMC7000 Microwave Oven
Microwave does not run though it has electricity. makes a clicking noise
When you say there is electricity, I take this to mean that your display, buttons, and countdown timer are all functioning normally, but when you press start no light, fan, turntable, or heating response occurs?
Normally the only thing that clicks on a microwave is the relay. If it is repeatedly clicking and nothing is happen, it could indicated that it has failed.
Repairing this will require some replacement parts (probably between 5 and $50) and whatever labour costs (if you do have it serviced, the shop should give you this estimate up front).
Remember, while you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, let me know and I will point you in the direction of some good resources.
Oct 21, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Hi our Haier HMW31AEDS microwave has the following problems. 1. It starts itself as soon as we shut the door. 2. The keypad does not work. 3. The only way to turn it off is to manually pull open the door...
I am 90% sure the running as soon as the door is closed is a bad door switch. This could possible explain all the issues with the unit. I would check that first
Nov 21, 2009 | Haier Microwave Ovens
JennAir JMC7000ADW Microwave Oven Not Heating Well
Assuming the turntable is working and the power at the outlet is correct (110 to 125VAC) then you almost certainly have a failing magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first: http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 22, 2008 | Jenn-Air JMC7000 Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable no longer turns
Your problem is either a weak or slipping motor or a broken / cracked turntable coupler. If the coupler turns loosely without actually engaging the motor, it is bad. If the coupler is good or looks good, it's probably the motor. One test of the motor is to firmly grab the shaft with pliers and try to gently turn it. It should turn with some resistance and make a whining sound as it turns, since it is a highly geared motor. If the motor turns very very freely - or not at all - then it is bad. You can see an exploded diagram and order parts via the Jenn-Air (Maytag) Web site at http://services.maytag.com/abs/PartsStore.do?nextPage=psstartpage You will need to enter your full model, which is apparently one of the following: JMC7000ADB JMC7000ADQ JMC7000ADW Referring to the CABINET-BASE-CAVITY diagram found there, you will see: - REF 23 motor - REF 27 coupler One of those is likely the culprit.
Dec 06, 2006 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
52 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
