Replacement window adapter for Delonghi T130Arc portable airconditioner
4 Suggested Answers
huuum
  • 750 Answers
SOURCE: DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
  • 134 Answers
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Hi I'm bill I just to want to ask something regarding about my delonghi ariagel ag75 7,500 BTU/h.its a portable conditioner with 3 modes.And ive been using this for almost a year now.And wasn't...
Hi Bill, I also have a Delonghi portable air-con, so I hope I can help. Is the machine working ok apart from the leak? Does it have a built in waste water tank as does mine? If so, take a look at where the tank is placed to empty the machine, it is possible that the pipe leading to it from the machine is out of position and instead of filling the tank with water, it is dripping on the floor instead. If you remove the water tank, the machine will not run on air-con, but if you have a look at where the tank fits in (you will need a torch) you should be able to see where the water is coming from.
These machines do create a lot of waste water, that is normal, but it should end up in the water tank, not on the floor, so you need to find out why it is not reaching the tank.
As to your problem with the manual, I have found these links for, Delonghi so that you can contact them directly and explain that you need a replacement. As I don't know what country you are in, I have put a few for you to try, they should forward the query, or refer you on.Hopefully, they will either email you with a copy, or they might post a replacement. Good luck!
http://www.delonghi.com/uk_en/agency/
http://www.delonghi.com/us_en/agency/
http://www.delonghi.com/au_en/agency/
Aug 21, 2011 | DeLonghi Heating & Cooling
I HAVE EVERSTAR PORTABLE AC, PLASTIC PIECE THAT ATTACHES HOSE TO WINDOW IS BROKE, I NEED NEW ONE, EVERSTAR WEBSITE IS NO HELP, I HAVE CONTACTED NUMEROUS TIMES, NO REPLY, UNABLE TO USE A.C.
Here is a link to where you may be able to find the part(s) you need. Have your Model Number handy, when searching for the right window adapter or hose end.
http://www.appliancefactoryparts.com/airconditioners/everstar/everstar-other-parts.html
Hope this helped you and thanks for choosing FixYa>
Aug 08, 2011 | Heating & Cooling
My DeLonghi CPC 505 Split System Airconditioner stops cooling when the outside temperature reaches 33degr Celsius
Check condenser coil is cleaned. Out door fan motor is working with full speed. If not replace capacitor. And also check Running capacitor.Check gas pressure, if newly charged. Thanks.
Feb 05, 2011 | DeLonghi Heating & Cooling
Hi I DeLonghi T130ARC model air con and no remote and getting a messgae of PF error does anyone know what this means Andrew
Hello my name is Heath it wil be my pleasure to assist you. The PF usually means there was a power failure and the only thing you can do is turn the power off to the unit unplugg the unit and let it sit for 15-20 minutes and then repower the unit and see if the pf goes away.
Aug 02, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Probe problem in portable airconditioner-DeLonghi Pinguin PacCT90
If you have located the probe or sensor, then it is usually possible to remove it and yes you can get replacement sensors at any refrigeration shop
Nov 18, 2009 | Heating & Cooling
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
nbenz ,
Welcome to fixya.
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi pac l90 air filter
Call 800-865-6330.  The white accordion 3M Filtrete filter is $37.95, and is NOT available on the Delonghi website.
May 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
