My hotpoint aquarius wmf540 keeps beeping 3 times every 10 mins or so. The cycle finishes with no obvious problems. Is this a warning?
    Master:
  • 818 Answers
Yes your washing machine is trying to tell you something-somethings wrong-are there any flashing lights while the beeps are happening-also do you have the owners manual-this is always a good place to start-cheers Denny
Posted on Oct 20, 2013
4 Suggested Answers
SOURCE: i have aquarius ,, lights keep flashing prior to
had a similar problem...sounds daft but have you unplugged it left it alone for 5 mins then tryed again? worked for mine.
Posted on Mar 02, 2010
SOURCE: I have a Hotpoint aquarius WMF540 washing machine
f01 RELATES TO A MOTOR PROBLEM , POSSIBLE CONTROL MODULE COULD CAUSE F01 TOO.
TRY THIS FIRST, " reset it : hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesn't always work 1st time so keep trying, good luck" If not then try the proceedure below.
unplugged the washer power supply, closed the water
- unscrewed two screws that hold the control panel
- removed the panel - you need the lid to be semi-opened
- (re-conected all connectors to fix any possible oxidation or unpluging - then tried the washer, but problem persisted)
- unscrewed all screws that hold the side cover - only the right one had actually been necessary (when standing in front of the washer)
- unscrewed all four screws hidden under the bottom cover in the front of the washer that hides also the filter (those still hold the side cover)
- unscrewed two more screws at the top back of the washer - they hold the circuit board to the washer body - it needs to be loose
- by pulling the top side of the washer up by the lid and pushing the side cover away "to the back" (with a screwdriver), see how the side cover is held by the top, remove the side cover
- observed the motor and immediately saw heavy corrosion at the ground connection (yellow-green wire) at the motor board and possible slight oxidation at one other connetion of the black wire
- using sand paper and screwdriver I've cleaned the contact together with the connector and tried the washer - still no effect
- cleaned the black wire connection with the same way
- tried the washer (spinning program) and - voila! It works!
- tried unplugging the black wire and running the spinning program - both the motor AND the pump didn't start
So, it looks to me that the problem was in an oxidation of the black wire connection - that is apparently a power supply for both the pump and the motor, that caused insufficient voltage and thus a power for the motor but probably still enough for the pump. The randomness of the problem was probably caused by humidity in the room and maybe some more factors - the washer is actually opened from the bottom so when I test the washer more times and see this as a solution, I'll probably cover the connetors with silicon to avoid corrosion or oxidation in the future.
Here are also some tips for putting all together:
When removing the side cover something fell from it inside. It was a plastic lath that is placed on the nearer edge of the cover and fits both onto the edge of the cover and the adjacent edge of the washer. It's a bit tricky to put it all back plus there is a plastic piece at the bottom of the side cover that is fixed there also very loosely and keeps falling inside when srewing the filter side screws - but this can be fixed with pliers adjusting the edge of the side cover to make the plastic to fit there tightly
http://www.servicematters.com/maytag_library/docs/16022808.pdf
Service manual, generic, to help troubleshoot.
Posted on May 21, 2010
jetimanski
  • 13 Answers
SOURCE: My Hotpoint WMF540 (Aquarius) keeps displaying DOOR error message
If it's an error code F17 close door firmly at the 3 O'clock position
if it's a F06 error code this indicates a faulty door lock or a fault on the electronics of the main board supplying the power too the door lock
try thisunplug the appliance--wait 10 minutes--give the handle a thump or two--try opening the door
If it doesn't open this suggests the door lock has failed. To manually open the door:
unplug the appliance--take top off--reach down inside and you will find the door lock in the middle of it--you should find the latch pin poking through the door lock push the latch pin over to open the door
If it keeps doing it I would suggest replacing the door lockwww.4hotpoint.co.uk can help you with that
Good luck--Hope this helps.
Posted on May 01, 2012
Testimonial: "Fantastic advice and cant thank you enough, your solution worked a treat and i got a few more washings out it before another message occured (H20?) but your help was recieved most gratefully!"
How will i know if it is the moter that is broken on my wmf540?
The WMF540 motor is usually quite robust, depending on the symtoms.... I would look at the Main control panel, and check the brushes on the motor.
Jul 11, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Where is filter on my hotpoint aquarius wmf540 washing machine, im getting white fluff over all my clothes everytime i put a wash on, im guessing the filter needs cleaning and just wondered where it is
http://laundry.manualsonline.com/manuals/mfg/hotpoint/wma58_wma56_wma54_wma52_wma50_wmm59_wmm53.html?idRes=599752
see last page.
also, you should try run a cycle without any clothes (add a bit of bleach) in it in cold water for once to rinse out the dirt.
Oct 02, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Kenmore Elite washer, Model 110.20096993, it starts beeping with about 10 mins left in the cycle and shuts off. Any thoughts?
I have the same model - it displays 10 minutes and keeps beeping in series of 3 (beep beep beep...... beep beep beep... etc..) ran through a cycle successfully but kept beeping like that the whole time. I unplugged it for 10 minutes but had the same symptoms after plugging it back in. I unplugged it for 24 hours, and that seems to have cleared the problem up.
Jun 12, 2010 | Kenmore Washing Machines
I have aquarius ,, lights keep flashing prior to
Mar 02, 2010 | Hotpoint Washing Machines
WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Washing Machines
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius fdw60 tripping problem
I would agree with you. Everything you say here certainly points to a faulty heating element. The original is fitted with two factory fitted clips so you may need to go to your local garage and get two jubilee clips as they don't usually come with the new element.
Jun 01, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
332 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
