Question about Tools & Hardware - Others
How do I replace bushes in my Craftsman 2.0A MULTI-TOOL
How do I replace the tool-less blade clamp in a craftsman 8 amp reciprocating saw
Craftsman Reciprocating Saw replace the tool-less blade clamp
Jun 10, 2015 | Craftsman Saws
Replace pilot shaft bushing 2000 3.3 liter nissan frontier
You'll need a special tool to get the bushing out and another to drive the new one back in. You;ll need to separate the transmission from the engine. It isn't necessary to remove the clutch from the flywheel to get at the bushing. The tool will remove the bushing with a wrench. The tool that us used to install the bushing is driven in with a hammer Mount the new bushing to the tool and tap it in the flywheel with the hammer. Since you didn't take the clutch off it'll be easy to mount the transmission back onto the engine.
Oct 06, 2014 | 2000 Nissan Frontier
Sears Craftsman snow thrower cable tension bracket broke.
just buy a bracket and a new bushing... easier that way.
also you can remover old bushing by soaking it in white vinegar ...
Oct 02, 2017 | Garden
How to close blade on craftsman 10 in 1 lighted multi tool ? #39045
I have one. It is a locking style blade. There is a lock that you need to push to release it. The lock looks like another tool next to the hinge of the blade. Push it against the base of the blade.
Dec 31, 2013 | Craftsman Saws
How do I get to the brushes in my Craftsman 2.0A Multi-Tool?
Call Sears parts at 1-888-204-3725 describe your tool and ask for a users manual and a parts explosion map.
Oct 20, 2013 | Tools & Hardware - Others
My Craftsman garage door opener is not working - I opened the inside of the opener and motor is humming but gears are like jammed....when I prod the gears with a screw driver they do spin for about 3...
I had the same problem. In my case the bushing for the main drive gear was worn out. This is just below the sprocket that connects to the chain.
What you should do is remove the chain and see if that sprocket shaft is loose in the bushing. The motor should turn without the chain on.
If this is the case check the plastic gears within the case. If there all chewed up and the bushing is shot you most likely need to replace the unit. If the gear's are still good you can replace the bushing.
I'm not sure how much Sears would charge to rebuild it but it is very possible it would be cheeper then buying a new one
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
How to chnge control arm bushing on 1994 dodge intrepid
Here are the instruction on how to replace your control arm bushing. please not that there is a special tool needed that you will need to get from you auto parts retailer. you can usually rent these tools.
    1. Turn the control arm over in the arbor press, then position the arm so that it is supported by the receiver tool MB-990799 as shown.
  1. Position the new bushing into the control arm so it is square with the bushing hole. Position the installer tool MB-6644-1 or equivalent on top of the bushing, with the bushing setting in the recessed area of the installer tool. Press the bushing into the control arm.
  2. Press the control arm bushing into the control arm until the installer tool squarely bottoms against the surface of the control arm. When the installer tool squarely bottoms on the control arm, the bushing is installed in the arm in the correct position.
  3. Install the tension strut into the strut bushing in the control arm. Position the tension strut in the control arm with the word FRONT stamped in the tension strut positioned away from the control arm. With an open end wrench on the flat of the tension strut to stop the tension strut from turning. Tighten the NEW tension strut-to-control arm retaining nut to 110 ft. lbs. (150 Nm).
  4. Install the lower control arm and tension strut back onto the vehicle. Refer to the Lower Control Arm procedure earlier in this section.
Control Arm-to-Tension Strut Bushing
To replace the control arm tension strut bushing, the control arm and tension strut assembly must be removed. The removal of the bushing requires the use of an arbor press.
  1. Thoroughly lubricate the replacement tension strut bushing, control arm and installer tool 6644-3 or equivalent with a silicone lubricant.
  2. By hand, install the tension strut bushing into the large end of the installer tool. Press the bushing into the installer tool as far as it will go by hand.
  3. Position the control arm in the arbor press so that the tension strut hole in the control arm is centered on the receiver tool MB-990799 or equivalent. Position the installer tool with the previously installed bushing, inside of the tension strut bushing hole in the control arm. Position the installer tool on top of the tension strut bushing. Using the arbor press, press the tension strut bushing into the control arm. As the bushing is being pressed into the arm, a pop will be heard. When the pop is heard, the installer tool will slightly move up off the control arm. At this time remove the control arm assembly from the press and pull the tool MB-6644-3 off of the tension strut bushing in the control arm.
Jun 19, 2010 | 1994 Dodge Intrepid
Loose gearshift
INSPECTION 1. Inspect the bushing for wear or damage. 2. Inspect the return spring for damage or deterioration. REASSEMBLY 1. Apply multi-purpose grease to the sliding parts of the bushings. 2. Reassembly is reverse of disassembly. INSPECTION 1. Inspect the bushing for wear or damage. 2. Inspect the return spring for damage or deterioration. REASSEMBLY 1. Apply multi-purpose grease to the sliding parts of the bushings. 2. Reassembly is reverse of disassembly.8fa5804.jpg
Apr 24, 2009 | 2003 Hyundai Santa Fe
Tools & Hardware - Others Logo
163 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
