Question about Kenmore Microwave Ovens
Kenmore model 721.80042 start button doesn't work
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
What if reset button on back doesn`t fix problem,what`s next to try? no lights no power
No power at all would point to a breaker or fuse for the power. You would have to open the back to have a look and test for voltage.
Jul 26, 2014 | Kenmore Elite Microwave, Model...
How do I fix the key pad of a Kenmore microwave model 401.80084700?
I don't know of anyway to repair the keypad. Usually replacement (of the keypad/control console) is the only option. But you might want to remove the ribbon cable that connects the keypad to the control board behind it, clean it with a degreaser (like Fantastic or 409), dry it, and re-insert it, and then try again. (Remember to unplug the microwave oven first before you try that!)
Jul 07, 2014 | Kenmore Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
ASKING FOR TIME OF DAY BUT WHEN I PUT IT IN IT WILL NOT DO ANYTHING WHEN I HIT THE START BUTTON. THIS MODEL DOES NOT HAVE A RESET BUTTON.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, you likely have a bad keypad.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Jot down your full model number and see here for more help.
Aug 22, 2010 | Kenmore 80012 Microwave Oven
Kenmore Microwave Hood Combination oven Model Service code (SE) ?
The 401 in the model number is the model prefix for Samsung, who manufactured the oven.
SE error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
I would need the rest of the model number from the tag to help you more.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/t2931196-kenmore_microwave_hood_combination_oven
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 12, 2009 | Kenmore Microwave Ovens
Kenmore 721 microwave fan turns on by itself
I have the exact same problem with my Kenmore Microwave model 721 that we bought in October of 2005. The Fan will just randomly turn itself on even when we are not cooking. It has been doing this for the last few months and is starting to become more frequent. There is no way to turn it off except to unplug it for several hours.
Was there a recall for this defect ?
Apr 25, 2009 | Kenmore Microwave Ovens
Start button on microwave does not work
Some numbers are missing off that model number. Would that be model 721.62622200?
(If not, please reply back with the correct model number off the tag)
If it's cooking with the programmed buttons, but Start is not working, it sounds like the keypad has failed.
The keypad for model number 721.62622200 is no longer available as a separate part.
So you'd have to buy the entire controller assembly, which includes the plastic frame, keypad, and circuit board, etc.
It is part # 4781W1M307A and it runs $110.10 at the Sears parts Web site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
