Question about Westinghouse Refrigerators
White Westinghouse RTD16VM frost-free fridge- The compressor is overheating and the control box cold control is not working. The compressor remains on till it becomes over hot and stops when the relay trips it. It starts again after it cools down to working temperature. Compressor does not start or stop when the cold control knob is turned or when the Refrigerator section and the freezer have reached the appropriate temperature.
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Westinghouse BJ424S-R: fridge section not cold/cool.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 20, 2010
espressonist
  • 1711 Answers
SOURCE: My Fridge GE Profile PDS22SBR,
We must admit that your description is a little shocking since you have replace so many parts and the two obvious that you should check first you did not even mention them.
The refrigerator is getting it coldness from the freezer by means of the evaporator fan Evap mtr asm.
Part Number: AP3743432 made by GE
which is located in the freezer department through the Dampner assy
Part Number: AP3775435 made by GE
So you should check if the above fan is working and if yes if the dampner is open free from ice or other object.
All the parts of your model can be found in this link below.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5210170&diagram_id=24642925#d24642925
Posted on Nov 01, 2010
  • 842 Answers
SOURCE: About kenmore model# 253.65802508. Compressor
HI,
First of all thank you very much for all the great detailed information. I wish I had a cheap repair answer for you, but is sounds like the unit is either open (one of the tubes to the seal system has cracked or broke) which will cause the problem you have, called a low charge. Before you go any further, look for oil around all the tubing you can see... THERE SHOULD BE NONE!! If you find oil, you have found your leak and this would need to be repair. You may need to professional to complete this for you. Or someone who have to proper equipment to seal this system up for you.
Good Luck
Posted on Jul 23, 2011
  • 2006 Answers
SOURCE: GE Artica PSS25MGMB Stopped cooling/freezing, everything else works,lights, fans, just no cold and no compressor start sounds?
I would suspect the start relay and capacitor! With the clicks and buzzes, that is the most likely fault. Although you could replace one or the other of them, I always replace as a mated pair, because it seems that when one of them fails, the other one will fail shortly after. Items 733 and 734 on the following schematic (which also gives you an idea of what they look like and where they are located)
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-PSS25MGMBBB/0432/0165000/G1090005/00009?blt=06&prst=&shdMod=
Posted on Jan 13, 2012
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Westinghouse Fridge/freezer RJ340M. Not freezing cold.
Could be several problems, it may have a leak in the coolant system, the compressor may be bad, or the control system may be malfunctioning.
Mar 17, 2013 | Refrigerators
Beko fridge freezer. The interior light still comes on but both the fridge and freezer compartments aren't getting as cold as should (probably about only 20%)
hi there. well if its a standard fridge it could be 1- the stat 2-lack of refrigerant 3-or motor.difficult to check without a visual but if your condenser is nice and warm and the motor is not overheating then it could be the stat.either change it or turn off fridge bypass the stat wire and try.it will over freeze.(keep safety in mind first) if frost free then again condenser warm ,compressor not overhated then likely to b your defrost timer.(normally hiden near compressor at rear/good luck Ali
Aug 26, 2012 | Refrigerators
GE fridge not cooling. freezer working ok. compressor fan not working
This is an odd thing to hear. Normally when the condensor fan (}compressor fan) Isn't running the freezer is the one who's temperature rises and the fridge stays about the same. I would strongly suggest looking at the main control board, just for the simple fact that 9 out of 10 times thats the root of the problem
Jun 06, 2012 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Freezer is frost free yet it is icing up its a refridgerator
I would recommend that you turn either the freezer down or the fridge. This is somewhat normal, even frost free units will produce some frost, and this is mainly due to the temperature being too cold. Some minor adjustments and you will be fine.
Mar 20, 2011 | Westinghouse Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
I have a Westinghouse frost free fridge with freezer on top.(RJ340M) Freezer part is working great but the fridge is not performing well at all. Thermostat was my first thought but wouldn't that be...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 23, 2010 | Westinghouse Refrigerators
Freezer works, but the bottom of the refridgerator does not keep food cold.
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help
Jul 27, 2010 | GE 17.9 Cu. Ft. Frost-Free Top-Mount...
My Westinghouse side by side frost free fridge freezer is freesing the food in the fridge and there is frost on the items in the freezer please help
Can be anything from a damper / cold control issue to a to cold freezer. As for the frost on the food items in the frzr. Most of the time it is normal, especially when the items are in bags or loosely wrapped. Air is the culpert,
air is a gas...at room temp you can't see it. As it cools it condenses to a liquid, as it gets colder it frosts to ice crystals. Vacuum pak or rap tight in plastic and then zip lock removing as much air as possible.
Mar 08, 2010 | Refrigerators
Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Feb 16, 2009 | Westinghouse Refrigerators
Refrigerators Logo
57 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
