How to replace tv tuner? - Televison & Video
  • 32 Answers
Open the tv from the back
find the circuit board with the silver box on it
find the numbers on it
order a new one
install
close back of tv
Posted on Oct 22, 2013
Philips powervision tv my tv tuner pin is broken
You're discussing about the input socket [Ariel socket] to your TV is broken; I assume, and posts this solution. In most cases, this is a irreparable fault; because, this socket is directly connected to the tuner, and is a part of tuner body [case]. If it is broken, the the tuner should be replaced with an identical one. You should check out the number of the tuner used with your TV; can be noted on it by a sticker. Just buy that number tuner, and replace it. The tuner can be bought from most of the electronic spare part selling shops.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Apr 17, 2014 | Televison & Video
There are two green lights blinking at the bottom of the tv. where the power light is..i believe it's the opc lights. the tv shuts of it self and the two lil green light blink...we put the tv power...
The tv main logic board known as a tv Tuner signal board it is the causes and the problems.The tv main logic board,the tv Tuner signal board it is shorted and not taking in and sustance power from the tv power supply board anymore that why tv Power and OPC LED lights indication are flashing together.This main logic tv Tuner signal board that the board where that take in the tv incomming broadcasting signal wire plug into it.U must replaced the main logic tv Tuner signal bard to fixed this problems.If U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main logic tv Tuner signal board for the replacement.Tries tv unplug,replug it back about an hour later.Tv might work again for awhile though,but to fixed this problems for good the main logic tv Tuner signal board must have to be replace.
Aug 22, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
I have INSIGNIA TV 42"
Hi shaan99,
There's some shop that expertised in tv tuner repair. But this shop is very hard to find and sometimes the cost will be the same like the original price of it. You can replaced the tuner by yourself, all you have to do is prepare soldering iron, disoldering pump and soldering lead and the tuner replacement http://cgi.ebay.com/ENV56S02D8F-TV-TUNER-/230591288708?pt=LH_DefaultDomain_0&hash=item35b04fd584#ht_500wt_949.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 13, 2011 | Televison & Video
Hitatchi Ultrascan HD 43" TV suddenly had what resembles double exposure, and the color went to bright pink and bright green. A friend gave us the TV, which we had had a few months.
Ur tv Tuner board,that the board recieving the incoming tv brostcast signal to the tv.That the Tuner board,it defective.Replaced the Tuner board will solved this problems.Tries Webdites like Shopjimy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 14, 2010 | LG 52LG70 52 in. LCD HDTV
The tv turns on with sound but the screen is just white
Ur tv Tuner board is dead.Replaced the Tuner board,u will get ur incomming cable or free air tv signal go through and get ur tv picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 05, 2010 | Sharp LC-26D6U 26 in. LCD Television
Tuner
the answer is yes. Once you get another tuner, simply use soldering iron to remove the old turner from the TV panel board and replace with another.
Good luck.
Apr 18, 2010 | Emerson SB350 13 in. TV/DVD Combo
TV ANT Jack Broke off and lost cable viewing
Yes it can be replace only if it just a connector adapter connected independently unto tv tuner. But if it is with the tv tuner as a whole. You will replace the entire tv tuner. Just bring the part as reference to your favorite electronic store selling tv parts.
Apr 11, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Tuner Problem
Robert,
Replacing the "F" connector is usually all that's needed unless the tuner board is cracked. You could remove the tuner - send it in for repair and re-install it... It would clearly save a few bucks!
Any shop should be able to do that one easy enough... Around here we charge $40.00 including the part to replace the "F" connector and there are shops that charge even less...
Bill
Feb 09, 2008 | RCA 20F512T 20" TV
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Oct 03, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
