I can't get my tv to play on my vcr/dvd it plays the dvd movie but won't play on tv and i can't get my tv. it like it want to play but something is stopping the channel from tuning in my tv won't go off channel 4 or video input in
  • betty waller
    betty waller Oct 20, 2013
    i don't have a BUTTON TO PUT MY VCR/DVD ON 3 OR 4 I THINK IT IS THE TV IT WON'T SHOW ANY CHANNEL ON THE ONLY CHANNEL IT WILL DISPLAY IS 3 AND VIDEO INPUT I CAN'T GET IT OFF THE CHANNEL 3 AND WHEN 4 COMES UP WHEN I SWITCH TO VCR IT HAS THE LETTER A IT WON;T LET ME PROGRAM ANY CHANNEL WHEN I DO CHANNEL SEARCH
    Problem Solver:
  • 17 Answers
Unplug your TV from the electrical socket and leave it for ten minutes then connect again . Try Autotune to find your stations
Posted on Oct 20, 2013
4 Suggested Answers
SOURCE: tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Posted on Feb 01, 2009
dodgecharger
  • 254 Answers
SOURCE: VCR stops playing
A couple of possibilities: the bad electronics unit might have power supply problems, optical sensor problems, or other problems with the electronics. If you have some tech savvy and a voltmeter, you could check the power supply voltages. This circuit is likely in the close vicinity of the fuse. On the output side you should see a +5 volt, +12 to 15 volt, and perhaps a -35 volt (approx). The +5 supplies the logic circuit, +12 the motors. If these voltages are missing, or way out of tolerance, you will have a dead unit. A frequent cause of problems in the supply is bad electrolytic capacitors, especially in the older units (Panasonic manufactured rigs, late '80s/early '90s). Possible values on these capacitors: 2200MFD/10V 1000MFD/16V and several others. Replacements can be supplied by MCM electronics, Mouser electronics. I use the Panansonic FC series from Digi-Key Electronics. Sensor problems: Many VCRs have the sensor opticals mounted on the main circuit board, and locate themselves in particular spots in the mechanical section. One or more sensors detect tape loaded, one each for the supply & takeup spindles. If any of these sensors (especially the supply/takeup sensors) are non-working, the logic circuit will detect an error condition, and shut down the unit or at least put it into a stop mode.
Posted on Oct 02, 2007
barbu51
  • 566 Answers
SOURCE: hi. My VCR will not record or play on channel 3
Hi chris If you mean that the tv has to be on channel 4 instead of 3 then look at the back of your vcr , there is a swich to select the output channels 3/4.
Hope this help
Posted on Dec 02, 2009
Why Philips dvd player won't play all dvd movies?
This is not a fault. Some movie burned formats might not support the player.
May 23, 2012 | Insignia IS-DVD1001 DVD Recorder/VCR
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
We have a GO DVD+VCR model No. DV2140. We cannot
If you are trying to play blue ray on this unit you are out of luck no amount of firmware will make it play something it is not capable of doing.
Aug 14, 2009 | Televison & Video
Unable to play a DVD movie
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
Dec 09, 2008 | GoVideo DVR4300 DVD Player/VCR
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Dec 04, 2008 | Televison & Video
All movies are coloured 'red' when played
This sounds like a protection issue.. is your setup something like DVD ->VCR -> TV if so you need to connect your VCR in another fashion or pt it VCR -> DVD -> TV.
Dec 01, 2008 | Philips MX1055D System
DVD'S will not play..
Sounds like the unit is bad, or set to the wrong Regional Code. Its not easy to set the regional code and it varies by model. You are better off buying a new DVD player given they can be found for under $30.
Aug 28, 2008 | Samsung DynaFlat CXM2785TP 27 in....
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Samir
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
VCR/DVD setup for color on LCD TV
check to see you have the cables required by the tv. usually you need hdmi or dvid for hd display. digital rights management protocols have resulted in chips in playing devices that allow only the use of the referenced cables to protect content from being copied. in some sets they default to not playing in hd, but still play something.
look there first, otherwise you may have an input source mismatch. follow instructions on the dvd player first, then make sure the tv has compatible settings.
if that does not solve, you have a service issue with one or both.
good luck
mark
Dec 17, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
