Question about Samsung Power Supply, Control Plate for SCC-641/ SCC-643 Smart Dome PTZ Cam
What is the color code for the proprietary Samsung cctv cable? Colors: Green, Red, Yellow, Black, Clear, Bare Copper. The Bare copper is wrapped around the Clear wire. RJ11e on each end.
    New Friend:
Ex2007321171
Posted on Oct 20, 2013
2 Suggested Answers
SOURCE: ssc-12c samsung b/w camera.
im trying to get the wiring dirgam for a ssc-12c camera
Posted on Sep 05, 2009
I have a lorex CA1090310741 model MC7540 color camera but the wires are cut.. I need to know which is what their are 4 wires red,white,clear coated copper and bare copper???
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Oct 03, 2017 | Lorex Home Security
I have a ccd color camera with a broken cable, the unmatched colors are red, white yellow, black and bare copper. the end line it needs to connect to has red, white, yellow, blue, green and bare copper,...
sorry partner you have a prob. no changing wires will ever work in the corder . try the shopping for systems that are compatible to the tv monitor hook up .. looks like a really nice camera too .
Aug 21, 2013 | Clover Corporation Home Security
Have a samsung ssc 17c need the wire digram
White wire with bare copper wire around it is for video. Center wire is positive, copper bare wire is ground. Red is +12v dc, Black is -12v dc, Green is audio +, while yellow is audio -.
Feb 01, 2013 | Home Security
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
HOW DO I CONNECT A JENN AIR MODELE C 202 C COOKTOP HAS 5 WIRES
Hello Ken,
What color are the wires i suspect they are red,black white,green or bare copper??
connect all the reds to the reds from the house wiring same for the black and white and connect the either green or bare to the green or bare wires
Nov 05, 2011 | Jenn-Air Cooktops
Vga cable color code of 17" monitor of samsung SyncMaster can u send color code pichear
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
Aug 03, 2010 | SAMTRON 55V 15" CRT Monitor
Hello sir i am sasi from india pls tel me international color codes electrical wiring
Well colors can vary, but basically bare copper or green are grounds, white is the neutral wire (but it is powered in a switch loop, and when used in a switch loop it is taped with a piece of electrical tape to show it is powered). Black, red, blue, brown, and pretty much any other color except green and white can be a power wire (black red and blue are the most common colors used).
May 26, 2010 | General Electric GE ELECTRICAL TQD22200X2...
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Colour code for 480v 3ph is it brn - orng- yellow?
Most typical local practices are; (Brown-Orange-Yellow) for 480VAC 3Phase
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripe for the protective ground. In principle any other colors except these may be used for the power conductors
Dec 02, 2008 | Heating & Cooling
Wiring problem
yes that is right, color to color turn of breaker before touching wires. green and bare copper go together.
Nov 01, 2008 | Jenn-Air JED8430 Electric Cooktop
Samsung Power Supply, Control Plate for  SCC-641/ SCC-643 Smart Dome PTZ Cam Logo
232 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
