Question about Vacuums
Need new roller for my 76p4e but can not find the (style) number, could you please tell me where it is, thank you
  • Vacuums Master
  • 2,113 Answers
Style 7, 9, 10, 12, 14 according to the net. Maybe type one in at a time on google images.
Posted on Oct 20, 2013
Power head roller brush
go to guarantee vacuum and sewing center tell them the exact model number of the unit and the serial number and the brand tell them what parts you need need and they will be able to get them for you
Mar 19, 2014 | Fantom Vacums Lighting Canister Vacuum
How do I remove the roller from the hoover c1429 vacuum cleaner in order to change the belt. Thanks.
That is an elite style upright. You will need to remove the hood by releasing for tabs around the outside of the hood/base. The brush will simply lift up. You may need to pry on the base with a flat blade GENTLY to get tabs on the ends of the roller out. I'll include a link to the correct belt.
Belt- http://www.vacuummedic.com/product.php?id=8
Good Luck!
Aug 22, 2012 | Hoover Vacuums
I got a cord wrapped around the roller, and now neither the roller nor the suction work...only hot air coming out the top of the base.
To unrap the cord from this vacuum you will have to do the following:
First turn the vacuum upside down and place head on counter and handle on the floor. You will have remove the base plate. There are 3 screws that hold it in place. Since cord is wrapped around the brush roller you will not be able to take it all the way off, but it will give you access to the brush roller. If the belt is still on the brush roller, I suggest you cut it, so you can lift the brush roller out of the base and that will make untangeling the cord easy. If you need a new belt here is the info on that.
Style "R" Extended Life. Eureka Part #61110 - Free Shipping Style "R" Extended Life cost is $ 9.99 for one
Apr 29, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
When machine is running the brush does not turn
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Apr 28, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuum base is not turning on but brush roller will turn on- Tri Star cannister/hose style
This indicates that you have a bad motor in the machine. If you are able to get power to the rest of the vacuum besides the motor, this means that the vacuum is getting power, and the motor's carbon brushes have probably worn out. I can look and see if the carbon brushes for the motor are availble, or if you'll have to purchase a new motor assembly completely if you can kindly do a clarification request or add a comment to this repair.
Please rate the repair suggestion as helpful by clicking the thumbs up icons if this answered your question.
Thanks,
Chris J.
Mar 21, 2010 | Vacuums
Brush roll turning very slow
You might need to clean out the roller brush. Here is the manual that has instructions:
Owner's Guide (1.5 MB download)
If you need a new belt you can get it here:
Eureka style D belt
Nov 21, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Hoover U5399-900 WindTunnel Vacuum
38528033 is the belt number or just 033.
40201160 is the part number for a 2 pk
sometimes they are referred to style 160 as well
All these are the same belt. Hoover makes things so simple don't they? LOL
Dec 02, 2008 | Hoover U5399-900 WindTunnel Lite Upright...
Bissell roller question
You need to replace the brush roll, part # 2032013, I would also put a new belt on as well, 2031093, style 7 belt.
Most vacuum repair shops should have these or can get them for you.
Aug 27, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
The brush roller cracked in half
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=568149
Generic problem for all Vacuums
posted by mjp000 on May 03, 2008
the brush roller cracked in half
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If your brushroll is cracked in the middle, 1st we need to know the brand name and model # of the vacuum that you are trying to replace the brushroll on. Then you can contact your local vacuum cleaner dealer in your area and they can sell you a new brushroll for the particular model, if not call the part s dept of the brand name such as: Hoover.com or Eureka.com and they will ship you out a new brushroll. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
