Wml540 Hotpoint not spinning
Belt keeps slipping off the wheel at the back and so cant spin...
    Master:
  • 818 Answers
Is the belt worn or old-its possible strechted-is there a belt tensioner that must be working freely also-cheers Denny
Posted on Oct 20, 2013
Testimonial: "The belt seems ok, we are thinking that maybe the wheel is warn? the belt slips off. We put it back on and it lasts for a few spins then off again, the spin seems a little off centre aswell."
  • 121 Answers
SOURCE: Hotpoint WMA32 Front Load... Problem:
if its not your belt its the brushes in the motor that need replaced i would replace the brushes first the cost about £15-20
Posted on Mar 03, 2008
  • 1122 Answers
SOURCE: My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Posted on Jul 12, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore 970-C41062-00 Spin cycle, belt keeps coming off
sounds as if yo umay have a bad rear bearing, and the off balance of it is "throwing " the belt. magor repair, and would ck with manufacture, for possible part warr
Posted on Mar 19, 2009
barkencoa
  • 3463 Answers
SOURCE: my Hotpoint Ultima keeps displaying an F10 fault
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Posted on Jan 17, 2010
  • 56 Answers
SOURCE: wml540
brushes on motor ? replace cost around £50.00 in total
Posted on Feb 11, 2010
Drum stopped spinning - Belt has come off - Wheel/drum stiff, no rotation. How to Fixya? Hotpoint IPX4 - 1669200001 - Grateful for any help / advice *********** - Cheers
You can do the repairs yourself, however be aware if the fact, the shroud surrounding the drum was stamped out from a sheet of metal and it has extremely SHARP edges that can slice your had or wrist wide open. Safety First. You must remove the rear panel and expose the back of the drum. Remove the spent belt and stretch a new one over the pulley wheels. Rest the drum shaft into the rotational collar on the back panel and fasten all screws tight in place.
Feb 05, 2018 | Dryers
2001 chevy Malibu belt slipping off, put it back on and it slipped off again. It's like something isn't spinning right.
Since the belt is off already check all pulleys if they spin freely. Check with the engine OFF, all pulleys should spin freely except the crank (big one at the bottom). If everything is spinning smoothly check the belt tensioner if it still has decent spring pressure to keep tension on the belt
Dec 26, 2017 | Cars & Trucks
Blade keeps slipping off.cant be put back on without spending 15+ minutes and a cut hand. Is there an easy way
There should be an adjusting knob to tip the upper wheel back and forth till you get it right to keep the blade tracking. This is similar in function to a belt sander adjustment.
To put the blade back on release the tension and carefully thread it though , wind the wheels manually, and gently guide it back in place, then reapply the tension.
Feb 27, 2016 | Blade Saws
Instructions hotpoint wml540
Check belt hasn't snapped/ come off,,,then check motor action,,,,put on spin and tap motor gently see if it helps
Jun 16, 2013 | Washing Machines
Belt keeps coming off
Hi There,
Most likely 1 of 3 problems.
1. The belt is stretched and so is just slipping off
Solution change the belt
2. THe brush roller has siezed bearings so brush cant turn properly so belt is slipping off the shaft.
Solution - check see if roller turns easily by hand if not change the bearings.
3. THe motor has twisted in its body due to cracked housing or worn rubber seats.
Solution- Depending on your skill and age of vacuum replace the housing or the vacuum.
If you need parts for your vacuum visit www.vacuumspot.com.au
May 13, 2012 | Oreck XL Ultra Bagged Upright Vacuum
The serpentine belt on my 1984 Buick Lesabre keeps breaking when turn on air conditioner or heater why?
Most likely you have a seized AC compressor. When you ask for AC or heat the AC clutch engages with the pulley wheel that normally spins freely when the AC is off. As the pulley wheel is no longer able to turn because of the seized compressor the belt will either slip or snap.
Sep 20, 2011 | 1984 Buick LeSabre
Hotpoint WML540 stops mid cycle, end of rinse going onto spin. Key lock light flashes, it also makes a banging sound as though washing trainers and then there are some clicking sounds before it stops. If...
maybe the concrete balancing weight has come loose and the fact that most of the water has been drained off when you turn it off for 10 seconds it does not have the one-sided affect anymore also check the damping springs as one may have come off in the violent spin eric
Dec 19, 2017 | Hotpoint Aquarius WMA42 Front Load Washer
I changed the alternator on my 99 alero an now it makes a loud sweeking niose is there a way to tighten the belt
LOOSE BELT MORE LIKELY YOU HAVE A BAD BELT TENSIONER.A BAD BELT TENSIONER WILL CAUSE BELT TO SLIP.WHEN THAT HAPPENS ALTERNATOR CANT SPIN FAST ENOUGH TO KEEP BATTERY CHARGE.AND IF YOUR WATER PUMP DONT SPIN FAST ENOUGH ENGINE WILL OVERHEAT AND YOU WILL HAVE POWER STEERING PROBLEMS ALSO HAVE DRIVE BELT TENSIONER CHECK OUT AT A GARAGE..
Aug 30, 2011 | 1999 Oldsmobile Alero
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
