Question about Canon FAX-L400 All-In-One Laser Printer
Rec. paper jam open right cover - Canon FAX-L400 All-In-One Laser Printer
  • 682 Answers
Obviously you have a paper jam somewhere. Probably one the right side, open all the covers and pull the paper out.
Posted on Oct 20, 2013
SOURCE: canon mf5650
Check the paper setting in your software. Paper size should be A4 in all instances. Hope it helps
Posted on Oct 05, 2007
SOURCE: jarry cannon
open printer cover, pull out toner cartridge, re-install cartridge, close door, it should re-boot the machine.
Posted on Sep 25, 2008
  • 537 Answers
SOURCE: Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Posted on Oct 21, 2008
MXM450
  • 62 Answers
SOURCE: PAPER JAM
laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
Posted on Jan 22, 2009
abhvp
  • 148 Answers
SOURCE: Paper jam message, but no paper visible
Are there any traces of paper in the printer? Have you tried by restarting printer?
Posted on Mar 18, 2009
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
I am getting rec.paper jam no paper jammed though
Open back door, clean feed roller very well, and open and close upper cover.
May 28, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Paper jam will not clear
you have a stuck or broken sensor
Jul 02, 2009 | Canon Office Equipment & Supplies
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
Mar 18, 2009 | Canon PC-D340 All-In-One Laser Printer
L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Oct 31, 2008 | Canon PC-1060 Black and White Copier
PAPER JAM
Oct 29, 2008 | Canon imageCLASS D320 Digital Copier
Oct 21, 2008 | Canon ImageClass D880 Copier
Jarry cannon
Mar 14, 2008 | Canon LaserBase MF5750 All-In-One Printer
Canon mf5650
Oct 04, 2007 | Canon LaserBase MF5650 All-In-One Printer
Canon FAX-L400 All-In-One Laser Printer Logo
100 people viewed this question
old marine
old marine
