Question about Epson Stylus 830U InkJet Photo Printer
When I print I get horizontal blue lines across the page. Have gone into Maintenance checked nozzle and cleaned many times, still get blue horizontal lines. Have replaced both cartridges still getting the same problem.
  • 682 Answers
Sounds like the print heads need cleaned, sometimes the software clean mode will not clean them good and you have to physically go in and clean them.
Posted on Oct 20, 2013
Basti
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
SOURCE: Epson stylus photo R2400
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
Posted on Sep 17, 2008
SOURCE: CX6600 Epson - prints blank pages
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
To remove and install only the Printer Driver for your CX6600, please perform the following steps:
Driver Removal
1. Go to START then SETTINGS and click on CONTROL PANEL ( START and CONTROL PANEL in Win XP) and double-click ADD/REMOVE PROGRAMS.
2. To remove the printer portion select EPSON PRINTER SOFTWARE and click on REMOVE. Ensure the correct printer model is selected on the uninstall utility.
3. Click OK and follow the prompts. If asked to confirm removal of any personal settings or shared files, click YES or OK.
4. Once the components are removed, power off your unit and disconnect the USB cable.
Installation
1. Go to http://support.epson.com
2. Under Welcome to Epson Support click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Download the most current driver for your printer and operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it is easy to find.
5. Once download is complete, close your internet browser. To install simply double-click the file you downloaded and follow the prompts.
6. Do not reconnect the unit until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer. Installation should complete automatically.
Posted on Oct 25, 2008
kd6rhd56
  • 400 Answers
SOURCE: Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Posted on Jul 12, 2009
  • 250 Answers
SOURCE: When I print blue horizontal lines appear or being printed as wel
Do the cartridges ride on the printing carriage, or do they plug in somewhere else in the machine and have hoses that run the ink to the print head? If they ride on the printing carriage and the cartridge is new, there could be a short in the printer and it needs repair. Check if there's ink smeared on the print head or part of the printer. Generously clean the print heads with lots of paper towels and rubbing alcohol. If that doesn't work, to see if it's an issue with computer, print a test page from the printer, but don't send the print job from the computer. You need a print job generated from inside the printer itself. Not every printer can do this, but try pressing paper feed, holding down paper feed and power, or holding down cancel and power. If the blue lines disappear then but they didn't when you cleaned the heads, it's a software issue.
Posted on Sep 17, 2009
THE PRINT IS NOT CLEAR
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
Apr 17, 2013 | Lexmark Office Equipment & Supplies
Printer not alligning catridge
Good Luck!!!!!!
Sep 15, 2011 | HP Photosmart C5580 All-In-One InkJet...
Photos are light with fine grainy appearance. Have tried the corrections in the manual without correction.
Good Luck!!!!
Jul 21, 2011 | Lexmark X3470 All-In-One InkJet Printer
Can print the color I want. Only prints red.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x 3350 multifunction. USB connected, reinstalled latest software for device from lexmark. Print quality is terrible and does not start at top of page - maybe 10 lines down. Also, new ink...
Aug 24, 2009 | Office Equipment & Supplies
Color cartridge do not want to print
May 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
I put a new ink cartrige and printer prints low coulour tone.
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
Can't print in color
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Bold lines on Fax and Scan
May 26, 2009 | Lexmark X7550 InkJet Printer
White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Nov 10, 2007 | Lexmark X5470 All-In-One InkJet Printer
Epson Stylus 830U InkJet Photo Printer Logo
167 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
