Question about D-Link DWM-156 3.75G HSUPA USB Adaptor
In the D-Link modem I got the error as ErrorID=678 The remote computer did not respond.To make sure that the server can be reached,ping the remote computer. what is the solution for it?
2 Suggested Answers
jaye_ellen
  • 591 Answers
SOURCE: D-LINK DFM-562E++ MODEM
Best I could come up with was http://www.dlink.com/products/?pid=DFM-562is&tab=3
Posted on Sep 16, 2009
I have dell studio 15 lap top with windows 7 operating system. yesterday i bought tata photon plus data card. when am try to connect i am getting 678 error: remote computer did not respond. I have...
This error is due to modem not responding problem, or signal strength is low.To cure this error, Follow the below steps :-
Goto start program - control panel - click on phone and modems options - A Window named as Location information opens
Select the country/region are you in now - then specify the area code (or city code) are you in now - then select tone dialing - click on ok button Phone and modem options window will open with the details you have entered in previous window...
Thanks & Regards
Anas K A
May 17, 2011 | Computers & Internet
VPN connection error
1) you are dialing the wrong number.
2) make sure you have good connection.
3) If using VPN, make sure the port 1723 and IP Protocol 47 (GRE) are opened.
Apr 04, 2008 | Televison & Video
Hi am getting error pop server3 not responding
simply you are not connected to the server. check IP address of the server and ping it. go to run type cmd and type ping space server ip and click enter. if you have four replies check your computer settings. if not try to connect to different server if still have same problem configured lan settings of the computer make sure its obtain and dns as well.
Jan 20, 2011 | Computers & Internet
I wasnt able to connect using my modem, then this appears error 679. What does 679 error means?
Error 678 and Error 679 Connection Errors
Error 678 The remote computer did not respond (No dial tone)
Error 679 The Specified destination is not reachable
Both errors are very closely related as they both suffer from the same causes
Causes
ISP (internet service provider) problem.
You have a phone line problem.
Router / Modem is disabled, this can be due to.
The LAN or Phone cable is disconnected.
Your firewall is blocking the connection.
The Winsock file needs to be repaired.
A phone line does not have a line filter installed.
The modem drivers are corrupt.
Spyware.
Your modem is faulty.
Your username, password is wrong.
Incorrect ISP or Router / Modem Configuration
Hope it helps.
Oct 09, 2010 | Computers & Internet
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
I want to use my se w395 as a modem. I have downlaoded teg software from tthe sony ericsso site ean installed it on my computer. As a test i wanted to call my house phone, but then i get "Error 678 remote...
i want to use my se w395 as a modem. I have downlaoded teg software from tthe sony ericsso site ean installed it on my computer. As a test i wanted to call my house phone, but then i get "Error 678 remote computer did not answer" Please help me
Feb 24, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Toshiba Satellite M45-S355 PC notebook modem device says it is working properly, but I keep getting a 678 Error code; the query test means nothing to me; I went out and bought a USB modem, which works, but...
The 678 error means that the modem is not connecting to the server because of problem at the server end. Contact the helpline of your service provider and ask them to rectify the problem at their end.
Nov 17, 2009 | Toshiba Satellite M45-S355 (PSM40U073001)...
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
ERROR 721: REMOTE COMPUTER DID NOT RESPOND
it is the problem with the tata indicom (VPN ) server ...please call them and tell abt error 721 : this is generally due to VPN firewall... please call then and they will solve the issue... call to customer care 121..
Jun 22, 2009 | Microsoft Windows Vista Ultimate Edition
I can't connnect to intrnet
SYMPTOMS loadTOCNode(1, 'symptoms'); When you try to establish a dial-up connection after you upgrade your computer to Microsoft Windows XP from Microsoft Windows 98, from Microsoft Windows 98 Second Edition, or from Microsoft Windows Millennium Edition (Me), you may receive an error message that is similar to one of the following: Error 721: The remote computer is not responding. Error 678: The remote computer failed to respond. Error 691: Access was denied because the user name and/or password was invalid on the domain. Error 777: The connection attempt failed because the modem or other connecting device on the remote computer is out of order. To resolve this issue, contact the hardware manufacturer to inquire about how to obtain and install the latest Windows XP-compatible driver for the modem or download an XP driver for the modem
Feb 14, 2008 | Computers & Internet
D-Link DWM-156 3.75G HSUPA USB Adaptor Logo
82 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
